97 Tacoma Partial Restoration Engine/Paint
Discussion in '1st Gen. Builds (1995-2004)' started by BamaToy1997, Mar 27, 2012.
  1. Apr 5, 2012 at 6:28 AM
    #41
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    wow, very nice shop! and the engine looks great! and one more vote for chain over belts. stupid idea for a critical part.
  2. Apr 8, 2012 at 9:40 AM
    #42
    mac424205
    mac424205 Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    is this what it's going to look like?
    http://www.tacomaworld.com/forum/1st-gen-tacomas/213948-pics-your-ride-detailed-out-post-up.html
  3. Apr 9, 2012 at 2:08 PM
    #43
    BamaToy1997
    BamaToy1997 [OP] Wheel Bearing Master
    Bill
    Navarre, FL
    As far as color? Yes. But no, I am not modifying my Tacoma to look like a Viper! hahaha
  4. Apr 10, 2012 at 6:22 AM
    #44
    BamaToy1997
    Bill
    Navarre, FL
    For those who have never seen the shop, here are two pics. It is hard to show it's true size, but I am at 4600 sq-ft. The last picture is the frame-up of the spray booth for my paint job, and our upcoming spray in bedliner product. My nephew and I knocked this out in about 2 days of after work frame work.
  5. Apr 10, 2012 at 5:42 PM
    #45
    BamaToy1997
    Bill
    Navarre, FL
    OK, I have finished building the new head. I lapped the valves to the valve seats and installed the new guide seals, as well as checked the springs. Installed the head and she is starting to really look like an engine! I was considering painting the head to match, but I like the two-tone look of raw aluminum v/s painted black.
  6. Apr 10, 2012 at 6:32 PM
    #46
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    That's one sexy looking engine! :D
  7. Apr 10, 2012 at 8:39 PM
    #47
    mac424205
    Mathew
    Chelsea
    paint it red. It will look awesome then. damn, already put together. UNLESS!!!! you can paint it still.
  8. Apr 10, 2012 at 8:41 PM
    #48
    mac424205
    Mathew
    Chelsea
    Ummmmm Bill.... How are you going to get your truck in there and paint it???? I have stared at this picture long and hard and cant figure it out!!!! (That might end up in someone's sig...)
  9. Apr 10, 2012 at 8:42 PM
    #49
    mac424205
    Mathew
    Chelsea
    Oh and your truck is dirty... well the frame is.... haha
  10. Apr 10, 2012 at 8:43 PM
    #50
    mac424205
    Mathew
    Chelsea
    why not? that would be awesome.... lol jk
  11. Apr 11, 2012 at 9:06 AM
    #51
    BamaToy1997
    Bill
    Navarre, FL
    If you look on the left side, where the door is, the entrance is framed up on that side. There is a brace that is just keeping things straight in front of it. the brace will come off when the rest is completed.
  12. Apr 11, 2012 at 10:05 AM
    #52
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    hes gonna drive through the door...:D
  13. Apr 12, 2012 at 8:28 AM
    #53
    GATORTACO92
    GATORTACO92 Well-Known Member
    Alex
    Hoover, Al
    2004 F-350 6.0 King Ranch
    2004 F-350...uh lots of motor work to go fast...er. Way to much to list. 2001: 3" leveling kit, ARB bumper, lightforce 240 blitz, 35" KM2s. SOLD 2008: OME 886s 90000 with dakars, LR UCAs, 5% tint, Satashi. SOLD 2015: Flooded and Gone
    i don't know if you know but you're missing a door knob....but thats really all you are missing:smack: haha
  14. Apr 13, 2012 at 5:21 PM
    #54
    BamaToy1997
    Bill
    Navarre, FL
    OK, I have been busy working, so I haven't updated too much here. So here we go. 2 posts, but that is because both are much different.
    Once the cylinder head is in place, it it time to torque the bolts. this engine, like so many other engine of the past decade, have what are called "torque-to-yield" bolts. what this means is that the bolts are torqued down tight enough that the bolt itself "stretches" a tiny amount. What this results in is that if you ever loosen the head bolts, they MUST BE REPLACED. If you do not replace the bolts, you risk failure of the head gasket. In order to properly tighten these bolts, you do what is called "torque angle" You tighten them down a small amount with a torque wrench (in this case, 26 lb-ft) in sequence, then you come back in 2 more steps in sequence, tightening them down again to a specific angle (again, in this case, 90 Deg.) So you first tighten all 10 head bolts to 26 lb-ft, then again 90 deg, then again 90 deg MORE. Make sure that you do each step IN SEQUENCE! Don't tighten the same bolt in all 3 steps! You do EACH step once for every bolt, then start over.This creates a very even torque pressure to be applied.
    If you look at the below photo you will see a torque angle meter that digitally shows you what angle you are at in tightening. There is even an alarm that beeps when you reach the programmed angle!
    Well after we got the cylinder head bolted on, we have to now get ready for the dual camshafts. If you have ever looking under the valve cover on these 2.7L babys, you will have noticed that instead of a chain driving both shafts, the chain only drives ONE shaft, where the other shaft is actually driven by gear from the primary shaft. When you set up the camshafts you first must make sure that the #1 piston is at TDC. At this point it still does not matter TDC compression or exhaust, because when you install the cams, YOU will set up the compression stroke. If you look from the rear of the engine, where the camshafts mesh, you will see marks on the splined gears. You will take the intake shaft with the larger mark, and line it up with the exhaust camshaft where it has a double mark as indicated in the photo.
    once that is done you can carefully place the camshafts into position and install the caps for the shafts. You must pay close attention here to the proper tightening sequence here for each shaft so that you do not bind or damage either shaft! Once you get them tightened down, you will verify that the marks are still aligned as in the above photo. If they are not, you can carefully turn them to get them in the exact position. remember, since they are splined you only have to turn one, it will turn the other.
    Now you will install the chain and sprocket for the primary camshaft. If you look at the top of the photo you will notice that there are 2 chain links that are a slight brass color, different from the others. This is the timing indicator, and they must be on opposite sides of the mark on the FRONT of the sprocket. Then you install the sprocket onto the camshaft, being sure that the mark is perpendicular to the cylinder head, and that the pin on the camshaft is in the same position, and splined to the sprocket. You can see all of this in the below picture.
    It may appear that the mark is not perpendicular, but that is because of the angle of the photograph.
    So recapping, the crankshaft timing mark is aligned with the mark on the crankshaft, the camshafts are properly aligned to each other, and the sprocket timing mark and timing chain are properly installed. To verify that everything is in it's proper place, you can rotate the engine with a ratchet on the harmonic balancer by hand through 2 full revolutions to make sure nothing binds. you do this over 2 revolutions in order to now bring the engine to TDC of the compression stroke, which you just created when you installed the camshafts and timing gears. After this you can install the valve cover, and the rest of the components. that is shown in the next post!!
  15. Apr 13, 2012 at 5:30 PM
    #55
    BamaToy1997
    Bill
    Navarre, FL
    Well now that we have the valve cover on, we reassemble the engine to get it ready for install. Then in it goes! I am happy to see the last photo in this post!!!
    Now it is time to install all of the electrical connections, fuel lines, and upper intake manifold. It was not installed prior to sticking the engine in because of the need to access certain parts of the bell housing of the transmission for bolts, and because I am waiting on new injector seats for the injectors.
    MORE TO COME! I hope SOMEONE is still watching this!!!
  16. Apr 13, 2012 at 5:38 PM
    #56
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    i iz :D
  17. Apr 13, 2012 at 6:28 PM
    #57
    GATORTACO92
    Alex
    Hoover, Al
    I was just there getting my parts!! Haha. Great work!!
  18. Apr 13, 2012 at 6:33 PM
    #58
    Davtopgun
    David
    Central Alabama
    Awesome Bill!
    Getting so close!
    We expect a video of it's first start up. :D
  19. Apr 13, 2012 at 7:48 PM
    #59
    jab08
    jab08 Well-Known Member
    Alabama
    02 T4R 4wd
    Awesome!!!! Cant wait to see it when everything is finished. Hope you take this many pics when you finally get to work on mine lol!!!
  20. Apr 13, 2012 at 8:10 PM
    #60
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Love this thread, nice work.
    Couldn't you just kinda guestimate 90* when tightening down the head, not needing that very expensive looking little gauge? Seems like the difference between 88* and 92* would be pretty minimal as far as torque goes.
