97 Tacoma Poor Engine Performance at high speed
Discussion in '1st Gen. Tacomas (1995-2004)' started by vhandy, Mar 4, 2010.
  1. Mar 4, 2010 at 6:28 AM
    vhandy
    vhandy [OP] Member
    Victor
    Tampa, FL
    97 Tacoma Ex Cab 4X4
    My 97 3.4l Tacoma 4X4 began experiencing poor engine performance at higher speeds (65-75 MPH). A description of the problem is the engine seem to start choking for fuel, and begins to shake. The last incident the check engine light came on and I limped it to my local garage. They ran diagnostics on it and determined that cylindar 5 was mis-firing. The replaced the Ignition coil, wires, replaced the spark plugs, cleaned the fuel intake and air intake sytem. I drove my Tacoma the following day and had the same issue at high speed. Has anyone else had this issue? I've already spend $650 and would prefer not to spend that much again for a simple fix. Thanks for your help.
  2. Mar 4, 2010 at 6:30 AM
    98tacoma27
    Ben
    Not Beech Creek
    What plugs did you use? And what were they gaped to?
  3. Mar 4, 2010 at 6:34 AM
    vhandy
    vhandy [OP] Member
    Victor
    Tampa, FL
    They used NGK Nickel Dual Tip Plugs. Not sure of the gapping.
  4. Mar 4, 2010 at 6:46 AM
    98tacoma27
    Ben
    Not Beech Creek
    Seeing how it is one cylinder pulling the code after all of those changes still, I would recommend doing a compression test on that cylinder. If that comes back good, then look at the injector.
  5. Mar 4, 2010 at 6:51 AM
    vhandy
    vhandy [OP] Member
    Victor
    Tampa, FL
    Thanks, I will have to take a loot at that today. It's just weird that it only happens at higher speeds. At least until the check engine light came on then its was hard just to keep it idling at a complete stop.
  6. Mar 15, 2010 at 1:47 PM
    abbaschild
    abbaschild Member
    Orange Co., CA
    1998 Tacoma 4WD
    Shell, carpet kit, rear suspension, wheels
    Did you replace the fuel filter?
    If it is the injector, sometimes having the injection system flushed will clear it up. I had an injector clog up on my 98. The cylinder was stone dead, even with new plugs. Cost me a bundle to replace b/c it was on the left bank, under the intake manifold.
  7. Mar 16, 2010 at 7:33 AM
    saweetlou
    saweetlou Well-Known Member
    Guelph Ontario
    TRD Dbl cab long bed
    3in spacer
    Did you check the coil pack, I just recently had the same issue and it was the coil.
