97 Tacoma won't go into gear
Discussion in '1st Gen. Tacomas (1995-2004)' started by VW2TOYO, Mar 6, 2016.
  1. Sep 15, 2020 at 6:52 PM
    Green Blur
    Green Blur Active Member
    Aram
    1997 Black Tacoma 3.4L 4x4 manual
    3 inch lift on 33s
    It shifts into every gear no problem with the engine off. It doesn't want to shift into 1st or 2nd...most of the time I can force it into 2nd better than 1st. It'll take about 15 mins until I can shift smoothly again. And the level is right at the max line and I just changed the gear oil today 75w90 Lucas full synthetic
    Dalandser[QUOTED] likes this.
  2. Sep 15, 2020 at 6:58 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Will it let you into 3rd and let you hill start it when the engine’s cold?
  3. Sep 15, 2020 at 7:07 PM
    Green Blur
    Aram
    3 inch lift on 33s
    To be honest with you I haven't tried getting into third. I just force it into either 1st or 2nd and just go from there. But once I get rolling it'll shift into 3rd and so on.
  4. Sep 15, 2020 at 7:48 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    I had the same problem a couple of years ago. I replaced the bushing that the shifter rides on, and it fixed it. BTW- I found the answer on this forum.
  5. Sep 15, 2020 at 7:50 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I’d check the bushing at the end of the shift knob before you replace the slave cylinder. It’ll only help diagnose your issue. Other people including me have had trouble shifting into some gears more than others and at startup (Mine wouldn’t go into first or reverse) due to that.
    Green Blur and 68dave like this.
  6. Sep 16, 2020 at 4:01 PM
    Green Blur
    Aram
    3 inch lift on 33s
    Thank you guys, the bushing will go in Saturday! I appreciate it.
    68dave and Dalandser like this.
