97 transmission and 2001 transmission
Discussion in '1st Gen. Tacomas (1995-2004)' started by razzo, May 12, 2025.
  1. May 12, 2025 at 5:29 PM
    razzo
    razzo [OP] New Member
    2001 tacoma prerunner 2.7 automatic
    N/a
    Hey fellas i have a question if some one can help me, i found locally a automatic transmission and Transfer case from 97 Tacoma 2.7 4x4 my concern its if will work on my 2001 tacoma prerunner 2.7 automatic? I want to do a 4x4 conversion on my prerunner!
  2. May 12, 2025 at 5:37 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    It should work, but how many miles on it? And doing a conversion and going auto?!?
    Moonrman and razzo[OP] like this.
  3. May 12, 2025 at 5:47 PM
    razzo
    N/a
    Mine its 2001 prerunner 2.7 automatic with 250k miles and the transmission and transfer case for sale its from a 97 automatic 4x4 tacoma with 200k miles
    MadNachos likes this.
  4. May 12, 2025 at 5:49 PM
    MadNachos
    I hear ya, but if you can drive a manual I would go that direction. But I wouldn't buy a used auto with 200K...ever.
  5. May 12, 2025 at 5:58 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I put a used A340F with 330k miles in my 120k mile truck :anonymous:
    MadNachos[QUOTED] likes this.
  6. May 12, 2025 at 5:59 PM
    MadNachos
    Nice. We could hang out...I like gambling.
    treyus30[QUOTED] likes this.
  7. May 12, 2025 at 6:03 PM
    MadNachos
    Don't get me wrong, I have taken risks on high mileage used parts in the past because I was doing the labor. And that's a fine way to go. But the older I get the less I take that risk. If you get a deal and can do the installation (and possible replacement again) I say go for it. But a used auto is always a crapshoot.
  8. May 12, 2025 at 6:12 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    The old stick shift modern anti theft deterrent.
  9. May 12, 2025 at 6:15 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    The A340F is a pretty stout transmission, ( still a gamble because you never know ) but if it never overheated and the fluid was changed a few times and it wasn’t abused . They can go for a very long time
  10. May 12, 2025 at 6:33 PM
    MadNachos
    Even better...neighbors ask to borrow a truck (as if) and you just ask if they can drive stick. Problem solved.
    Moonrman[QUOTED] likes this.
  11. May 12, 2025 at 6:36 PM
    MadNachos
    It's that "what's the ATF taste like" part that is often the problem. In my experience only "car guys" change ATF. But these are old enough that it's not out of the question that someone took care of it. But nothing sucks more than draining ancient ATF. All the stink, and sometimes you just watch the friction material just leave.
  12. May 12, 2025 at 6:40 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Ok, I’ll bite and be the only useful one in the thread for @razzo .
    your 2001 pre runner 2wd automatic is an A340E
    The 4x4 is an A340F
    output shafts are different (spline and/or length, that’s for you to do deeper research).
    either way if you keep and adapt your E transmission or swap the F over, you’re going to need to move or get a new crossmember(s) to support the transfer case and transmission.
    you need an ECU that is compatible with your 2001 engine as well as the driveline you choose.
    lastly, the transfer case in the earlier (before 2002 or 2003) were J-shift pattern and the later (2003-2004) were mostly or all the “2-4 auto select” push button style.
    These transfer cases have different sensors and plugs.
  13. May 12, 2025 at 6:41 PM
    JasonLee
    15 TRD OffRoad
    There are MANY 4x4 conversion threads on here with full parts lists and specifics on the different years and models (4Runner) parts that will work.
    start searching. It’s a lot of work.
