98-00 Tacomas Only
Discussion in '1st Gen. Tacomas (1995-2004)' started by clickws, Mar 10, 2016.
  1. Oct 14, 2021 at 6:18 PM
    #2021
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I'd do a new set of leaves regardless of the choice of front end replacement. Remember, these things are 20 years old.
    FW_Taco likes this.
  2. Oct 14, 2021 at 8:07 PM
    #2022
    SLAPS 65
    SLAPS 65 Dirty deeds, done dirt cheap..
    Leif
    Nor Cal east Bay Area Ca.
    2000 Tacoma 4wd ex cab 3.4 auto.. manual hub, J shift
    My well worn 2000 with 290k7B149F4F-3976-4E44-8306-1C3F8C6C5D94.jpg 41B69136-81E5-4170-B06A-76A89FAC3055.jpg I’m kicking around going with black flares, anyone know if the black flares are a textured plastic or the same fiberglass ones just painted black instead of body color.
  3. Oct 14, 2021 at 8:23 PM
    #2023
    khail19
    khail19 Well-Known Member
    Khail
    Reno, NV
    2000 Prerunner SR5
    01-04 flares were the textured plastic, 00 and earlier were fiberglass. I have the newer flares on the rear of my truck, haven't found a set of fronts to match yet
  4. Oct 14, 2021 at 8:42 PM
    #2024
    SLAPS 65
    Leif
    Thanks for the info, so on your truck you have the 98-00 fiberglass front flares painted black? They look much skinnier than the ones on my truck, maybe just the angle and lighting?
    How are you attaching the 01-04 flares?
    From what I understand they clip to holes in the surface of the fender/bedside.
  5. Oct 14, 2021 at 11:12 PM
    #2025
    khail19
    Khail
    Reno, NV
    2000 Prerunner SR5
    Mine were black when I bought the truck. They definitely look skinnier than your flares to me as well. The 01-04 flares are held on with the screws inside the wheel well. It holds them on fine without all the clips, and I wasn't going to make a bunch of square holes in my bedsides.
    SLAPS 65[QUOTED] likes this.
  6. Oct 15, 2021 at 12:58 AM
    #2026
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    Mine has been through a lot of changes...
  7. Oct 15, 2021 at 5:23 AM
    #2027
    Badknees
    Badknees Well-Known Member
    Kenny
    Anderson, SC
    1998 Tacoma Extended Cab SR-5 4X4
    King Front Coil-overs, Bilstein Rear Shocks, Add-a-leaf Rear Leaf Springs, 16" Toyota Wheels, KO2 Tires, Alpine 2-Din Head Unit, Alpine Amp, JBL GTO Speakers, Undercover Hard Bed Cover, Back-up Camera
    I had the chrome fender flares and replaced with the Bushwacker OEM Style black. These have a smooth finish. Everything fit perfectly, although I know these aren't the cheapest option!
  8. Oct 15, 2021 at 5:35 AM
    #2028
    Badknees
    Kenny
    Anderson, SC
    Nice truck and I like the cap. What type is it?
  9. Oct 15, 2021 at 10:13 AM
    #2029
    coldaccord
    coldaccord Well-Known Member
    André
    Buffalo, NY
    2000 Tacoma 3.4L 4x4
    thanks. Cap is a SnugTop Super Sport
    Badknees[QUOTED] likes this.
  10. Oct 18, 2021 at 2:04 PM
    #2030
    99PreV6At
    99PreV6At Active Member
    Gene
    Phoenix metro
    1999 Prerunner V6
    Question, got rid of the OEM aluminum wheels today and replaced them with OEM spare rims. I'm curious to know if the little spot in between the lug nuts is okay to hit up with a light dusting of black spray paint.
    Have a PreRunner btw.
  11. Oct 18, 2021 at 4:34 PM
    #2031
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    Yes
    99PreV6At[QUOTED] likes this.
  12. Oct 20, 2021 at 7:41 PM
    #2032
    Jbend
    Jbend Well-Known Member
    Can you give me a side shot with the 5 stars? Had them on my 4th gen 4runner I just don't know how they'll look on our trucks...but it looks like they look good. Not about the SCS cult.
    FW_Taco[QUOTED] likes this.
  13. Oct 22, 2021 at 12:42 PM
    #2033
    FW_Taco
    FW_Taco Well-Known Member
    2019 Tacoma TRD Off-road 4x4
    I ended up buying the ome kit with the whole leaf spring assembly with shackles. Thank you! Going to install soon.
    Brake Weight[QUOTED] likes this.
  14. Oct 22, 2021 at 12:50 PM
    #2034
    FW_Taco
    Sure, here you go. They are falcon wheels 17x9 0 offset with 265/70r17 tires. This is the perfect size for the 1st gen in my opinion and the offset is perfect. I've gotten a lot of compliments on these wheels from people (even people who aren't into cars).
    (One trick to making 265s look bigger than they actually are is getting a 9 inch wide wheel)
    BYJOSHCOOK and Brake Weight like this.
  15. May 25, 2022 at 9:06 PM
    #2035
    TacoMitch58
    TacoMitch58 New Member
    '99 Taco
    3" lift on OME medium/heavy springs, hidden winch
    Added an AMP'd UP hidden winch tray with an Ironman 4x4 winch to my '99 Taco.
  16. May 26, 2022 at 7:21 AM
    #2036
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Looks like your truck has dip in it's mouth haha. Don't see too many hidden winches on first gens :thumbsup:
    AMPdUPllc likes this.
  17. Jun 21, 2022 at 1:56 PM
    #2037
    mopar2
    mopar2 Well-Known Member
    Franklin TN
    Just bought a 99 Prerunner and looking for fender flares, is the ones on your truck stock?
  18. Jun 21, 2022 at 2:04 PM
    #2038
    mopar2
    Franklin TN
    Do you have the part number for the flares? Just bought a 99 Prerunner and want to get rid of the chrome ones.
  19. Jun 22, 2022 at 6:52 AM
    #2039
    Badknees
    Kenny
    Anderson, SC
    Here's what I bought. Again, they're not cheap but do fit and work well.
  20. Jun 23, 2022 at 7:53 AM
    #2040
    mopar2
    Franklin TN
    I’ve had Toyota for a long time now, first was a 1985 last year for the straight axle and just gave my 3rd Gen to my son. I just bought a 99 Prerunner with 2.7 auto and just started rebuilding it so I can put 100K on it. Going to ask
    Thanks
