98-00 Tacomas Only
Discussion in '1st Gen. Tacomas (1995-2004)' started by clickws, Mar 10, 2016.
  1. Jun 23, 2022 at 7:56 AM
    #2041
    mopar2
    mopar2 Well-Known Member
    Franklin TN
    Pic of my 99 Prerunner. I picked it up a few weeks back here in TN after we gave our son my 3rd Gen. Pic of my 3rd Gen also.
    6084A3B0-85B5-414E-BE7A-369413D8D974.jpg 4ED8AFC3-469B-4E24-A4F7-C52D99BDE122.jpg
  2. Jun 23, 2022 at 8:05 AM
    #2042
    Badknees
    Badknees Well-Known Member
    Kenny
    Anderson, SC
    1998 Tacoma Extended Cab SR-5 4X4
    King Front Coil-overs, Bilstein Rear Shocks, Add-a-leaf Rear Leaf Springs, 16" Toyota Wheels, KO2 Tires, Alpine 2-Din Head Unit, Alpine Amp, JBL GTO Speakers, Undercover Hard Bed Cover, Back-up Camera
    Dang, you're a great Dad!...will you adopt me? I'm pretty old and high maintenance, but know how to use a weed eater!
  3. Jun 23, 2022 at 8:32 AM
    #2043
    mopar2
    Franklin TN
    We couldn’t ask for a better son, he served his Country, awesome dad, and my best friend.
    Badknees[QUOTED] likes this.
  4. Jun 23, 2022 at 2:14 PM
    #2044
    DiverDan
    DiverDan Member
    99 Prerunner
    Finally finished buiding this '99 Taco. Couldn't find any better wheels to mount on this truck so I stuck with what's reliably pretty. Went with glossy for much easier cleaning out the many holes in this rim.
  5. Jun 25, 2022 at 1:11 PM
    #2045
    mopar2
    Franklin TN
    Replacing the front struts and want to know how to get the lower bolt back in? I’m having a hell of a time trying to get the lower A arm low enough to get it in. New LBJ also.
    jsway9 likes this.
  6. Jun 26, 2022 at 10:55 AM
    #2046
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    A long pry-bar (like 2-3 foot) over the UCA near the ball joint, seated under the UCA mount. Pull down on the bar to push the UCA, spindle, and LCA down.
  7. Jun 26, 2022 at 11:13 AM
    #2047
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I keep a 5or6’ 1” steel pipe for stuff like this. Pry down on the lower A arm because the bushings are tight enough to hold it in place. Once the weight of the truck is on it she’ll be fine. Also, do any spring compression on the ground as it’s easier
  8. Jun 26, 2022 at 11:31 AM
    #2048
    Kwikvette
    Fresno County
    4 run, 2 don't
    Easy, bottle jack and push the entire assembly down.
    Good thing those aren't taller shocks! Coilovers meant for a lift have an even tougher time.
    Badknees likes this.
  9. Jun 26, 2022 at 2:33 PM
    #2049
    mopar2
    Franklin TN
    I used the bottle jack, very easy. Thanks!
  10. Jun 28, 2022 at 7:56 AM
    #2050
    etank82
    etank82 Member
    Eric
    Atlanta
    2004 Toyota Tacoma 4WD Double Cab
    1998 w/ 91k original miles. 1-Owner, Southern-kept, rust-free. Currently on Bring a Trailer if anyone is interested!
  11. Jun 28, 2022 at 4:39 PM
    #2051
    Stiney84
    Stiney84 Active Member
    Edward
    Georgia
    1999 Tacoma
    20220627_180827~2.jpg 20220627_180906~3.jpg Hello everyone I'm new here. Here is my 99 Tacoma
    Taco Wedo, TForan, ztwatson and 2 others like this.
  12. Jun 28, 2022 at 9:26 PM
    #2052
    packman62
    packman62 Member
    Mesa, AZ
    1999 White Tacoma Pre Runner Ext TRD
    Here is a picture of the back of my 99’ fender flares. These were only used on the 98’, 99’, & 2000 PreRunners. That’s why they are slimmer than the 01’ - 04’. They are fiberglass and not the ABS plastic.
  13. Jun 29, 2022 at 5:46 AM
    #2053
    mopar2
    Franklin TN
    I’m looking for some to go on my 99 Prerunner, I have the small chrome and running 265/75.
  14. Jun 29, 2022 at 1:52 PM
    #2054
    packman62
    packman62 Member
    Mesa, AZ
    I too am looking for the factory fronts for my 99’ PreRunner. I had a Polaris UTV hit my right front fender over the Memorial Weekend and cracked the fender flare. Hope you’re successful with your search!
  15. Jun 29, 2022 at 1:56 PM
    #2055
    Archaic2021
    Archaic2021 Well-Known Member
    I like that color.
    What size tires are you running.
  16. Jun 29, 2022 at 1:58 PM
    #2056
    packman62
    packman62 Member
    Mesa, AZ
    Khail19, did you ever find the front flares you were looking for? I need the front factory flares you have for my 99’ PreRunner and would gladly buy yours should you decide to sell them! Hint hint!
  17. Jun 29, 2022 at 2:05 PM
    #2057
    Archaic2021
    Sharing my 99...bought it May of last year with 300k on the clock. Sold my 18 f-150 to get out of debt and this was the cash car to do it. Went from $700 truck payments to this.
    Paid 3k for the truck...replacing front struts, rear shocks, cv axles. all seals in transfer case and front chunk. Alternator, 1 set of tires and a radio...Got about 4500ish in truck. Drive it 90 miles a day for work...sitting at 340k.
    Truck has more than paid for itself. I have a 97 silverado 2wd my grandad left me as soon as it gets brakes and tires these will share daily duties. The paint sucks and would like to do a bed liner type paint and a lift with 33s since it won't be every day but this little 4wd has more than paid for itself.
    Taco Wedo, Winkle99, TForan and 3 others like this.
  18. Jun 29, 2022 at 5:51 PM
    #2058
    Stiney84
    Edward
    Georgia
    1999 Tacoma
    Thank you it's rhino liner olive drab paint and I just have some 31×10.5×15 on it for now
  19. Jul 3, 2022 at 12:58 PM
    #2059
    Stiney84
    Edward
    Georgia
    1999 Tacoma
  20. Aug 23, 2022 at 12:54 PM
    #2060
    Aces-89
    Aces-89 New Member
    1996 Toyota Tacoma
    what size tires lift are you running here?
