98-00 Tacomas Only
Discussion in '1st Gen. Tacomas (1995-2004)' started by clickws, Mar 10, 2016.
  1. Mar 14, 2016 at 9:55 AM
    #41
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I just put 33's on mine. Also regeared to 4.88 as well. I couldn't imagine running 33's w/o a regear. Mine was already slow before with 31's and 3.91's
  2. Mar 14, 2016 at 1:57 PM
    #42
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    98-00 are cool, but 99s are the best.
    Here is mine.
    4.7l v8
    R150F 5speed
    FZJ80 rear elocker axles
    35" Tarz
  3. Mar 14, 2016 at 2:04 PM
    #43
    clickws
    clickws [OP] Well-Known Member
    South Carolina
    1999 Toyota Tacoma Xtra Cab 4x4 2.7L 5-Speed All Manual
    Stock Alloys w/ 31.5x10.5x15 (Previously Black Pacers w/ BFG KM2 32xx11.5)
    There it is...
    COMAtized99[QUOTED] likes this.
  4. Mar 14, 2016 at 2:07 PM
    #44
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    1999 4x4 3.4 v6 sr5
    285/75/16 ko2
    5100 bilstien front n back with aal
    02' bumper swap
  5. Mar 14, 2016 at 2:08 PM
    #45
    COMAtized99
    North Carolina
    99 DCLB v8
    Many moons ago I had 33x1250s on my truck. I had an auto, then 5speed. It would hunt gears on hills, but really, if you are not in a huge hurry it was OK. If it where me, I'd run 5.29s and just let the 3rz rev.. 4.88a would be a happy medium though... I had 4.56 gears and they where not all that great...
    clickws[OP] likes this.
  6. Mar 14, 2016 at 5:36 PM
    #46
    boostedka
    James
    NM
    I agree. After driving around just a few days on this set up I couldn't imagine having less than 4.88 especially since I'm at 5000ft elevation. I'm at 3200 rpm at 75 mph and the truck just cruises. I ran it w 31's for a week and it was only 200 rpm higher and still cruised easily and not any louder from the motor revving higher
  7. Mar 14, 2016 at 6:21 PM
    #47
    TheLastLatin
    TheLastLatin Well-Known Member
    Isaiah
    Gatesville Texas (Central Texas)
    2019 Toyota Tacoma TRD Sport 4X4 Manual Transmission Cement Grey
    Zero worth bring up, bought it 6/17/2019 with 3 miles on it
    Almost all OEM, I'm in the middle of restoring my Tacoma back to all original at the moment. I have put some thought into some after market lighting but its going to be as stealth down low mods as possible.
  8. Mar 14, 2016 at 10:10 PM
    #48
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    This thread is Yota neglection:pout:
  9. Mar 15, 2016 at 2:56 AM
    #49
    COMAtized99
    North Carolina
    99 DCLB v8
    Huh?
  10. Mar 15, 2016 at 8:35 AM
    #50
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    My '02 wants to play :D:rofl:
  11. Mar 15, 2016 at 8:41 AM
    #51
    Madjik_Man
    Colorado Front Range
    I'll play.
    1998 3.4 5-speed TRD. (don't let the 95-97 front end swap fool ya)
  12. Mar 15, 2016 at 9:46 AM
    #52
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    I had 32" MTs on my last 2.7 5-speed, but it was a 04 with 4.30s. What gears do you have?
  13. Mar 15, 2016 at 11:33 AM
    #53
    JKO1998
    JKO1998 Well-Known Member
    Utah
    GQ7227, TacoMatt253 and JAMEDYota like this.
  14. Mar 15, 2016 at 12:36 PM
    #54
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
  15. Mar 15, 2016 at 6:03 PM
    #55
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    did you debadge it your self? i really like the clean look and easier waxing but i'm worried about how it will turn out on a 15 yr old truck thats had badges on it its whole life...
  16. Mar 16, 2016 at 7:33 AM
    #56
    TheLastLatin
    Isaiah
    Yeah I did. The Truck is 17 Years old and the paint wasn't in the best shape already so I wasn't too scared of messing it up. I used a putty Knife as flat to the body as possible and just pulled it away from the body of the truck. after that I just rubbed off all the residue with a house hold multi surface cleaner, and just cleaned the hell out of it. If you are looking for the shadowing of the emblems you can barely make it out, but you have to know what to look for and where they where. After I get it all waxed down I'm hoping it wont even be viable. My Only worry is the truck seems like its missing most of any layers of clear coat after all these years and the emblem locations are like factory fresh after being hidden all this time.
  17. Mar 16, 2016 at 7:46 AM
    #57
    FirstGen Jer
    Jeromey
    If you do plan on removing emblems and are looking for the best method without doing damage to the paint. Use a heat gun or blow dryer to make the glue in the emblem tape more workable then use fishing line to get behind them and work the emblem off. Off coarse with the heat gun don't go over board with holding it in one spot for too long.
    Taco Wedo and Steven G like this.
  18. Mar 16, 2016 at 7:48 AM
    #58
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Hair dryer took way too long and didn't do much at all. So just go with heat gun but don't be an idiot with it. Take your time but don't leave it sit in one spot move it around. Kind of like spray painting it but instead of paint its heat! :D
    FirstGen Jer likes this.
  19. Mar 16, 2016 at 7:49 AM
    #59
    TheLastLatin
    Isaiah
    What FirstGen Jer Said!
  20. Mar 16, 2016 at 7:52 AM
    #60
    FirstGen Jer
    Jeromey
    Ya I used my lady's blow dryer. But she don't mess around and has top of the line stuff when it comes to her beauty products so that thing works good! Lol it got hotter than my harbor freight heat gun. But I agree josh in most cases a quality heat gun will be better imo.:thumbsup:
    Taco Wedo likes this.
