98-00 Tacomas Only
Discussion in '1st Gen. Tacomas (1995-2004)' started by clickws, Mar 10, 2016.
  1. Dec 7, 2016 at 11:12 AM
    #661
    Jebediah
    Jebediah Well-Known Member
    Eli
    Colorado
    1998 White TRD.. 'Augustus'
    I agree. I'm workin on it....
  2. Dec 7, 2016 at 11:20 AM
    #662
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Speaking of retrofits
    I'm scared what I got myself into
  3. Dec 7, 2016 at 11:31 AM
    #663
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    I do believe that I've breathed some new life into this thread.
    Love that grill by the way
  4. Dec 7, 2016 at 11:32 AM
    #664
    jsway9
    jsway9 Ninja
    Monterey CA
    2000 Toyota Tacoma 4x4 TRD SR5
    Front Relentless Bumper Rear Outdoor Logical Swing Out Front King Coilovers Rear Fox Shocks All Pro Expo. Leaf Springs
    I want to see!
    retroboy1989 likes this.
  5. Dec 7, 2016 at 11:34 AM
    #665
    WildLand
    Josh
    NM
    16T4RSR54WD
    I do too! Haven't opened it yet. I just want them on my truck but don't really want to go through the process of doing it myself. But for $120 for the kit I couldn't pass it up! Hopefully I'll have them done by the end of the month. hopefully they will come out looking as clean as this but for 1st gen headlight
  6. Dec 7, 2016 at 12:10 PM
    #666
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    It's not hard! take your time and ask questions if need be. It's been about 2 years but I'll try to help if you need. Just ask :thumbsup:
    Yeah it's been dead until recently. Thanks! The PO did it and I get a lot of compliments on it :cheers:
  7. Dec 7, 2016 at 12:28 PM
    #667
    Burnett
    Burnett Well-Known Member
    Nolan
    North Georgia
    98' Xtra cab v6 4x4 evergreen pearl
    Bilsteins 5100's & 5125's, OME Dakar leafs Custom toolbox Custom bedstep/towhook/reverse light combo Custom Bedrack
    Will do!
  8. Dec 7, 2016 at 1:13 PM
    #668
    WildLand
    Josh
    NM
    16T4RSR54WD
    Thanks man! I do have one question already, lets see if I can explain it right.
    So when I put the projector in is there a certain way to do so? Is it the lightbulb that makes the beam at an angle or is it the projector? Do I put the headlight on my truck without the cover to get it straight then put the cover back on?
  9. Dec 7, 2016 at 1:16 PM
    #669
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Just slap it in like regular. There is a shield inside the housing that makes the cut off. Yup you get it all done except putting the cover back on and you line it up. Be sure to make measurements with tape on where your beam pattern is prior to starting
  10. Dec 7, 2016 at 1:18 PM
    #670
    WildLand
    Josh
    NM
    16T4RSR54WD
    Thanks!
    So I do all the adjusting with the cover off? What if when I put it all back together and find the headlights are too high, can I still adjust the height with the screw on the back of the headlight like normal?
  11. Dec 7, 2016 at 1:20 PM
    #671
    BYJOSHCOOK
    Josh
    Check Out My Builds
    That's why you want to get it just near perfect prior to putting the cover back on. But I'm pretty sure you can still adjust the height in the back, I need to adjust mine but :rolleyes:
  12. Dec 7, 2016 at 1:25 PM
    #672
    WildLand
    Josh
    NM
    16T4RSR54WD
    Ahh I see. Thanks!
  13. Dec 7, 2016 at 5:28 PM
    #673
    jgill21
    Jake
    Nashville
    When you're a noob and don't know what PO stands for. Can someone help me out? :rofl:
    BYJOSHCOOK[QUOTED] likes this.
  14. Dec 7, 2016 at 5:28 PM
    #674
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Previous owner...
    jgill21[QUOTED] likes this.
  15. Dec 11, 2016 at 7:58 AM
    #675
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Old picture but it's proof I had one
  16. Dec 11, 2016 at 8:03 AM
    #676
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    Looks like a clean truck!
    DustStorm4x4[QUOTED] likes this.
  17. Dec 11, 2016 at 8:09 AM
    #677
    DustStorm4x4
    U S A
    04 Jeep LJ
    Oh yeah it was. The entire thing showed very little wear at all for its age. There was only one problem though, it wasn't 4wd. Hence my truck now :)
  18. Dec 11, 2016 at 8:11 AM
    #678
    bry838
    oregon
    Lol that certainly was a problem...
  19. Dec 11, 2016 at 4:34 PM
    #679
    jgill21
    Jake
    Nashville
    Twins
  20. Dec 11, 2016 at 4:47 PM
    #680
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    My dad had a couple of these - great memories - he had a 94 at one point too - wonder why I ended up with an 81, 97, and my 08? lol
