98-00 Tacomas Only
Discussion in '1st Gen. Tacomas (1995-2004)' started by clickws, Mar 10, 2016.
  1. May 9, 2017 at 5:27 PM
    #901
    Bassed98
    Bassed98 Member
    Ben
    Louisiana
    98 Tacoma 5spd 4WD
    Complete Old Man Emu Suspension Kit from Wheelers Offroad: NitroCharger Sports front and rear, 883 coils, Dakars, front trim packer, greasable shackles and Wheeler’s poly bushings, extended stainless rear brake line and u-bolts. Wheels and Tires: Old: Pro Comp 7069 16x8 BFGoodrich All-Terrain T/A KO2 285/75R16 New: Pro Comp 7069 15x8 BFGoodrich Mud-Terrain T/A KM2 33X12.50 4XInnovations front plate bumper (Powder coated locally @ Niko Industries) Exhaust: 14" MagnaFlow muffler (11225) dumped after axle Cat-Delete (replaced with 2.5" bolt on test-pipe bought off ebay) DIY O2 sensor simulator mod http://www.toyota-4runner.org/3rd-gen-t4rs/175242-how-make-your-own-rear-o2-simulator-%245.html (Very happy with this exhaust setup! It's decently loud when you accelerate, but quiet enough to have a conversation when going a steady speed or cruising 70mph on the highway.) Very similar sounding to mine: https://youtu.be/Njqqlu2WSdE CS 144 140A alternator w/ 1-7/8" pulley, and Denso to Delco conversion pigtail 150A circuit breaker wired in-line with the alternator Dual Battery Setup: New: Deka AGM marine group 34s Old: Optima group 27 blue tops Were over 7 years old and still going strong, so I swapped them out. (Got rid of the factory air filter box, and made a custom stainless battery tray to go in its place) (Made a new "Autzone and O'Reilly special" ghetto cold air intake) It gets the job done! Stereo: Outdated Alpine head unit Polk Audio DB651s Alpine KTP‑445U Power Pack Rockford Fosgate 1500.1bd (1500w rms @ 2 ohms) 4 Rockford Fosgate Punch HX2 8s Custom 3.0 cu.ft. ported enclosure tuned @ 40 Hz Ebay black Euro headlights with LEDs Old: (Black Projector Halo Headlights) Nite-Shaded parking lights and blinkers Diaz Fabrication Devil Horn Emblem Tip Top Signs SR5 Off Road Badges (for more horsepower)
  2. May 10, 2017 at 6:50 PM
    #902
    jsway9
    jsway9 Ninja
    Monterey CA
    2000 Toyota Tacoma 4x4 TRD SR5
    Front Relentless Bumper Rear Outdoor Logical Swing Out Front King Coilovers Rear Fox Shocks All Pro Expo. Leaf Springs
    Got these in today!
  3. May 11, 2017 at 8:42 PM
    #903
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    Gonna take the truck on a 300+ mile trip soon and I want to change transmission fluid. Why does the manual say it only takes 2.5quarts, that's definitely not enough. What about a fluid filter, I can't seem to find one anywhere
  4. May 11, 2017 at 9:46 PM
    #904
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Why do you say it's not enough?
  5. May 11, 2017 at 10:38 PM
    #905
    SKINNER902
    SKINNER902 Active Member
    1998 Tacoma TRD Off Road
  6. May 12, 2017 at 5:07 AM
    #906
    jgill21
    Jake
    Nashville
    I just don't see how an "Offroad" truck will only hold 2.5quarts of ATF, while my minivan holds nearly 10
  7. May 12, 2017 at 6:06 AM
    #907
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    2.5 qt is not the whole system, that is just the pan when you drain and fill.
    jgill21[QUOTED] likes this.
  8. May 12, 2017 at 7:17 AM
    #908
    mataco4wd
    mataco4wd Well-Known Member
    994wd
    Bump since top and antenna re locate, bed liner with textured roller did a nice job on the top.20170506_123757.jpg
    ID4VID, BYJOSHCOOK, jgill21 and 3 others like this.
  9. May 12, 2017 at 8:06 AM
    #909
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    This x2.
  10. May 12, 2017 at 8:26 AM
    #910
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    i'd pass, but its difficult to tell if the tires are in good condition and how much tread is left.
    I got brand new 265/75/16s Cooper AT/3s delivered for $366 with warranty. Smaller, used tires with unknown mileage, age and potentially uneven wear for $240, meh
    boostedka and Dalandser like this.
  11. May 12, 2017 at 2:34 PM
    #911
    jgill21
    Jake
    Nashville
    Ah, ok. What fluid do you guys recommend? We do have transmission fluid filters, yes?
  12. May 12, 2017 at 4:05 PM
    #912
    jsway9
    jsway9 Ninja
    Monterey CA
    Installed this. Last week.
    Taco Wedo, jackn7, Chipskip and 6 others like this.
  13. May 12, 2017 at 7:35 PM
    #913
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Which company made those?
  14. May 12, 2017 at 11:56 PM
    #914
    jsway9
    jsway9 Ninja
    Monterey CA
    Front is Relentless.
    I think the rear is OutdoorLogic
    Dalandser[QUOTED] likes this.
  15. May 15, 2017 at 12:25 AM
    #915
    Cutter_
    Cutter_ I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    The mouth-breather editions of the first gen
  16. May 15, 2017 at 4:55 PM
    #916
    Jag72lc
    Jag72lc Member
    J
    1998 Tacoma 4x4 2.7
  17. May 15, 2017 at 9:27 PM
    #917
    jsway9
    jsway9 Ninja
    Monterey CA
    Anybody running Rear Fox 2.0 Smoothies from All Pro?
    What bushings do they switch?
  18. May 18, 2017 at 3:46 AM
    #918
    YotaBlue
    YotaBlue New Member
    Chad
    1998 Tacoma SR5
    Flowmaster Super 40 muffler swap Front end level 15x8 Fuel Anza Wheels Smoked turn signal markers Smoked tail lights and third light
    First post. Here's my 98 3.4 4x4. It's got 15k on the new motor and 145k on the chassis.
    MTgirl, Chipskip, BYJOSHCOOK and 2 others like this.
  19. May 18, 2017 at 6:22 AM
    #919
    SKINNER902
    Thanks for the feedback, I was more interested in picking up a second set of rims but I ended up passing and picking up some new duratracs instead :thumbsup:
  20. May 18, 2017 at 6:24 AM
    #920
    nzbrock
    Noah
    San Marcos, TX
    put my logo emblem on my new grill
    Taco Wedo, Dalandser and boostedka like this.
