98-00 Tacomas Only
Discussion in '1st Gen. Tacomas (1995-2004)' started by clickws, Mar 10, 2016.
  1. Oct 18, 2017 at 4:57 PM
    #1221
    GEENYUSS
    GEENYUSS Well-Known Member
    Colfax, CA
    1998 TRD Off-Road 3.4V6
    Icons, SPC UCAs, Solo Motorsports Mid Travel LCA, Fox 2.0, All-Pro Exp Leafs, 285/75/17 BFG KO2s
    Thanks 33x12.5x15
    jackn7 and boostedka[QUOTED] like this.
  2. Oct 18, 2017 at 5:22 PM
    #1222
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah I watched a few in depth diy's and heard the same thing again and again with the rollers - to buy more of them and only use them for so long. I'd probably try to find a better method of transferring the paint through experimenting if I was going to roll it with different types of rollers (I used to paint houses so I know a few things I'd probably try). Since the body panels and doors are easy to remove on these I might just spray them piece by piece and get the parts that don't come off easily separately. It's not a lot of extra masking and the panels can be put in a position that makes them easier to spray - especially the hood. Get one of these setups if you're going to spray. It cuts masking time in half on places where you can use it. The paper is cheaper at home depot ($3 a roll or so).
    https://www.amazon.com/3M-M3000-Han...1508372492&sr=8-1&keywords=3m+masking+machine
    https://www.amazon.com/3M-Hand-Mask...coding=UTF8&psc=1&refRID=9Q3P10ZGCKP3C1VYYRTD
    https://www.amazon.com/MPG9-3M-Hand...coding=UTF8&psc=1&refRID=BGYNAHEK5WMBVGM58GZN
  3. Oct 19, 2017 at 8:14 AM
    #1223
    Kittenmittens4U
    Kittenmittens4U Well-Known Member
    Sam
    Denver, CO
    98 Xtracab TRD 3.4l Evergreen Pearl
    Airaid MIT w/deckplate mod Grey wire mod 265/75/r16 Duratracs 2.5 Extended Travel King Coilovers Built Right Fabrication Uca's OME Dakars W/AAL and 10' Bilstein 5125's Toytec U bolt flip and extended brake line.
    TacoMatt253 and BYJOSHCOOK like this.
  4. Oct 19, 2017 at 9:28 AM
    #1224
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    That has to have a body lift or something. Those tires are tiny
    Here's 285s with mine and I have way less fender space then him
  5. Oct 19, 2017 at 9:39 AM
    #1225
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    My kid's 2000 PreRunner that dad has sunk waaaayyy too much money into but...
    Just put Katzkin leather inside, steering wheel restoration. When is enough enough?
  6. Oct 19, 2017 at 9:45 AM
    #1226
    GEENYUSS
    Colfax, CA
    His bed is on the frame no body lift. Looks like a 4” lift in rear with king coil overs maxed out on 31”s. Mine looked similar till I got 33”s. also running stock rims so makes it look taller
  7. Oct 19, 2017 at 9:55 AM
    #1227
    Kittenmittens4U
    Sam
    Denver, CO
    I'm fairly certain that there's no body lift, I am going to do new body mount bushings here soon though so I'll get rid of it if there is! Honestly my ride height is way off from where I want it to be. I got 650lb coils with my kings in preparation for a bumper/winch/skids and just put them without any adjustments. I'm also sky high in the rear because I wasn't aware that when installing my new OME leafs (w/aal) that I'd have to cut my stock shackles off. I was doing this on a Sunday and needed my truck drivable by Monday, so all I could find were 1.25inch lift shackles. When everything settles a bit I'll probably get some stock shackles or ome greaseable ones and then try and lower the front some. Your truck is kind of my inspiration so I'm hoping to have it sit at a similar height.
  8. Oct 19, 2017 at 9:58 AM
    #1228
    Kittenmittens4U
    Sam
    Denver, CO
    Yep pretty much, except I traded the stock 15inch split 3's to a buddy for his 16inch ones and I'm running 265/75/16.
  9. Oct 19, 2017 at 9:59 AM
    #1229
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Well he's gotta got 35's then because those look tiny as hell
  10. Oct 19, 2017 at 10:04 AM
    #1230
    Kittenmittens4U
    Sam
    Denver, CO
    I know, it's driving me crazy looking at it! What really sucks is I just finished paying those tires off too. They look great at the stock ride height in my profile pic though!
    jackn7 likes this.
  11. Oct 19, 2017 at 10:08 AM
    #1231
    GEENYUSS
    Colfax, CA
    Yes the front you can tell ur camber/caster is way off
  12. Oct 19, 2017 at 10:16 AM
    #1232
    Kittenmittens4U
    Sam
    Denver, CO
    I think so too, but the alignment shop swears by their numbers, camber and toe are both close to zero with the caster close to 2. I'll have to find the printout with exact numbers.
  13. Oct 19, 2017 at 11:00 AM
    #1233
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Go vote for me if ya want
  14. Oct 19, 2017 at 11:27 AM
    #1234
    GEENYUSS
    Colfax, CA
    Maybe it’s just the picture.
  15. Oct 29, 2017 at 10:16 AM
    #1235
    Bassed98
    Bassed98 Member
    Ben
    Louisiana
    98 Tacoma 5spd 4WD
    Complete Old Man Emu Suspension Kit from Wheelers Offroad: NitroCharger Sports front and rear, 883 coils, Dakars, front trim packer, greasable shackles and Wheeler’s poly bushings, extended stainless rear brake line and u-bolts. Wheels and Tires: Old: Pro Comp 7069 16x8 BFGoodrich All-Terrain T/A KO2 285/75R16 New: Pro Comp 7069 15x8 BFGoodrich Mud-Terrain T/A KM2 33X12.50 4XInnovations front plate bumper (Powder coated locally @ Niko Industries) Exhaust: 14" MagnaFlow muffler (11225) dumped after axle Cat-Delete (replaced with 2.5" bolt on test-pipe bought off ebay) DIY O2 sensor simulator mod http://www.toyota-4runner.org/3rd-gen-t4rs/175242-how-make-your-own-rear-o2-simulator-%245.html (Very happy with this exhaust setup! It's decently loud when you accelerate, but quiet enough to have a conversation when going a steady speed or cruising 70mph on the highway.) Very similar sounding to mine: https://youtu.be/Njqqlu2WSdE CS 144 140A alternator w/ 1-7/8" pulley, and Denso to Delco conversion pigtail 150A circuit breaker wired in-line with the alternator Dual Battery Setup: New: Deka AGM marine group 34s Old: Optima group 27 blue tops Were over 7 years old and still going strong, so I swapped them out. (Got rid of the factory air filter box, and made a custom stainless battery tray to go in its place) (Made a new "Autzone and O'Reilly special" ghetto cold air intake) It gets the job done! Stereo: Outdated Alpine head unit Polk Audio DB651s Alpine KTP‑445U Power Pack Rockford Fosgate 1500.1bd (1500w rms @ 2 ohms) 4 Rockford Fosgate Punch HX2 8s Custom 3.0 cu.ft. ported enclosure tuned @ 40 Hz Ebay black Euro headlights with LEDs Old: (Black Projector Halo Headlights) Nite-Shaded parking lights and blinkers Diaz Fabrication Devil Horn Emblem Tip Top Signs SR5 Off Road Badges (for more horsepower)
  16. Oct 29, 2017 at 10:25 AM
    #1236
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Any side shots?
    Bassed98[QUOTED] likes this.
  17. Oct 29, 2017 at 10:32 AM
    #1237
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Damn, I'm really digging the way this truck sits! She's nice! Which coils are you using upfront?
  18. Oct 29, 2017 at 10:37 AM
    #1238
    Bassed98
    Bassed98 Member
    Ben
    Louisiana
    98 Tacoma 5spd 4WD
    Thanks! NitroCharger Sports with 883s
    jackn7 likes this.
  19. Nov 8, 2017 at 10:27 PM
    #1239
    99toytacotrd
    99toytacotrd Member
    groves
    1999 toyota tacoma
    what bumper do you have on that?
  20. Nov 20, 2017 at 2:25 PM
    #1240
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    Guys, I fucked up.
    Frame isn't hurt, but the unibody is bent up pretty badly as well as the rad support. What should I do?
