98-00 Tacomas Only
Discussion in '1st Gen. Tacomas (1995-2004)' started by clickws, Mar 10, 2016.
  1. Apr 27, 2018 at 11:37 AM
    #1381
    jsway9
    jsway9 Ninja
    Monterey CA
    2000 Toyota Tacoma 4x4 TRD SR5
    Front Relentless Bumper Rear Outdoor Logical Swing Out Front King Coilovers Rear Fox Shocks All Pro Expo. Leaf Springs
    Put this on yesterday
  2. Apr 27, 2018 at 12:01 PM
    #1382
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    You need some sliders! Looks good, loving the contrast black & white
  3. Apr 27, 2018 at 12:07 PM
    #1383
    jsway9
    jsway9 Ninja
    Monterey CA
    Thanks man. I have some sliders i bought a couple year's ago. I'm finally getting to it. Gonna weld them on in 2 weeks
    Dalandser and BYJOSHCOOK[QUOTED] like this.
  4. May 7, 2018 at 7:49 AM
    #1384
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Are you using wheel spacers?
  5. May 8, 2018 at 7:12 PM
    #1385
    tacom4x4
    tacom4x4 Member
    Tacoma 4x4
    Lowerballjoints
  6. May 9, 2018 at 10:58 AM
    #1386
    tacomah7
    tacomah7 Well-Known Member
    Brendan
    1999 Tacoma 4x4
    3" suspension lift (Sway Away 2.0 Racerunners with eibach 14" 650lbs coils) All Pro Offroad Rear Expo Leafs w/ toytec boss shocks 4crawler 1" body lift Trail gear front bumper & rock sliders Trail gear rear bumper w/ custom tire carrier 33x12.5x15 Cooper Stt Pro Glare led 42" curved lightbar spidertrax 1.25" wheel spacers on the front Smittybilt 9500 winch Trd E locker w/ 12voltguy harness
  7. May 9, 2018 at 12:28 PM
    #1387
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
  8. May 9, 2018 at 12:34 PM
    #1388
    BajaSurfRig
    BajaSurfRig Well-Known Member
    2000 Tacoma 4wd Trd 5sp Callen Camper
    My 2000 4wd TRD:
    [​IMG]DSC_0148[/url] by Matt Sawyer, on Flickr[/IMG]
    I agree that the years 98-00 are the best. This is my second 00 and I love it!
  9. May 10, 2018 at 4:20 AM
    #1389
    david9kelsey
    david9kelsey Well-Known Member
    David
    Murrieta Ca
    00' Tacoma PreRunner
    So glad i found this thread!
  10. May 10, 2018 at 4:22 AM
    #1390
    david9kelsey
    David
    Murrieta Ca
    Did you move the turn signals into the side marker case?
  11. May 10, 2018 at 8:09 AM
    #1391
    Floridagulfcoasttaco
    Floridagulfcoasttaco Well-Known Member
    Noah
    1999 Tacoma extended cab prerunner
    Yea I wired up some dual filament 1157 bulbs in there so I still have running lights and turn signals in the side markers
  12. May 10, 2018 at 8:11 AM
    #1392
    Bassed98
    Bassed98 Member
    Ben
    Louisiana
    98 Tacoma 5spd 4WD
    Complete Old Man Emu Suspension Kit from Wheelers Offroad: NitroCharger Sports front and rear, 883 coils, Dakars, front trim packer, greasable shackles and Wheeler’s poly bushings, extended stainless rear brake line and u-bolts. Wheels and Tires: Old: Pro Comp 7069 16x8 BFGoodrich All-Terrain T/A KO2 285/75R16 New: Pro Comp 7069 15x8 BFGoodrich Mud-Terrain T/A KM2 33X12.50 4XInnovations front plate bumper (Powder coated locally @ Niko Industries) Exhaust: 14" MagnaFlow muffler (11225) dumped after axle Cat-Delete (replaced with 2.5" bolt on test-pipe bought off ebay) DIY O2 sensor simulator mod http://www.toyota-4runner.org/3rd-gen-t4rs/175242-how-make-your-own-rear-o2-simulator-%245.html (Very happy with this exhaust setup! It's decently loud when you accelerate, but quiet enough to have a conversation when going a steady speed or cruising 70mph on the highway.) Very similar sounding to mine: https://youtu.be/Njqqlu2WSdE CS 144 140A alternator w/ 1-7/8" pulley, and Denso to Delco conversion pigtail 150A circuit breaker wired in-line with the alternator Dual Battery Setup: New: Deka AGM marine group 34s Old: Optima group 27 blue tops Were over 7 years old and still going strong, so I swapped them out. (Got rid of the factory air filter box, and made a custom stainless battery tray to go in its place) (Made a new "Autzone and O'Reilly special" ghetto cold air intake) It gets the job done! Stereo: Outdated Alpine head unit Polk Audio DB651s Alpine KTP‑445U Power Pack Rockford Fosgate 1500.1bd (1500w rms @ 2 ohms) 4 Rockford Fosgate Punch HX2 8s Custom 3.0 cu.ft. ported enclosure tuned @ 40 Hz Ebay black Euro headlights with LEDs Old: (Black Projector Halo Headlights) Nite-Shaded parking lights and blinkers Diaz Fabrication Devil Horn Emblem Tip Top Signs SR5 Off Road Badges (for more horsepower)
    20180504_110852.jpg Out with the 285s! In with the 33s! (Dirty 3s)
    20180504_110943.jpg 20180504_110956.jpg 20180504_133950.jpg 20180504_133937.jpg
  13. May 10, 2018 at 8:32 AM
    #1393
    BYJOSHCOOK
    Josh
    Check Out My Builds
    What bumper is that?
  14. May 10, 2018 at 10:00 AM
    #1394
    boostedka
    James
    NM
    Looks like a 4xInnovations
  15. May 10, 2018 at 10:20 AM
    #1395
    Bassed98
    Bassed98 Member
    Ben
    Louisiana
    98 Tacoma 5spd 4WD
    Yeah, it's a 4xInnovations plate bumper. They ship it bare metal, so I had it powder coated locally. It's a direct bolt on, but I'm still going to weld the end caps on the frame whenever I get a winch. I'm pretty happy with it. If I had to buy another one I would probably get a relentless fabrication. They are the most aesthetically pleasing and the most similar to the old Elite bumpers.
    4xInnovations is one of the few front bumpers made that does directly bolt on. All the others require you to cut 3 inches off the frame rails and re-weld the end caps back on.
    BYJOSHCOOK and bluzrider like this.
  16. May 10, 2018 at 10:20 AM
    #1396
    BYJOSHCOOK
    Josh
    Check Out My Builds
    That's what I'm thinking. It looks like All-Pro (the turn signals) but also an Elite but the winch cutouts aren't correct.
  17. May 10, 2018 at 10:31 AM
    #1397
    bluzrider
    bluzrider Well-Known Member
    Phil
    OC
    '99 Prerunner V6
    Lifted, big tires & supercharged 2wd
    Here's my supercharged '99. Still runs great! Slowly working on some new updates. Dust lights are gone now, hope to install LEDs soon.
    Current setup (which seems like I've had forever!!):
    - Pro Comp 4" lift kit and replaced front PC spacers and stock shocks with King coilovers adding another 1"
    - Rear Bilstein 7100s and Deaver leaf pack
    - Eagle Alloy 16x8 wrapped with BFG 305/70R16 MT
    - Bushwacker Fender flares
    - Demello sliders
  18. May 10, 2018 at 10:37 AM
    #1398
    boostedka
    James
    NM
    Nice! I like how that bumper fits the front end of these 98-00's. Good to hear it is a direct bolt on as well. Thanks for the feedback
    rybern and Bassed98[QUOTED] like this.
  19. May 11, 2018 at 8:44 AM
    #1399
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    More pics of your camper and setup?
  20. May 11, 2018 at 8:54 AM
    #1400
    BajaSurfRig
    @Chipskip here you go:
    Here is me set up on one of my favorite beaches:
    [​IMG]DSC_0388 by Matt Sawyer, on Flickr
    Here is a shot of the inside showing the kitchen drawer. I made my own drawer slides with unistrut, casters and some ply. It works really well even when it is loaded up with a couple of weeks of food.
    [​IMG]20180430_164903 by Matt Sawyer, on Flickr
    Here is a shot of the pantry :broccoli:
    [​IMG]20180430_164328 by Matt Sawyer, on Flickr
    The camper is a Callen made down in El Cajon. It is great because it is well insulated (so you can sleep in even when the desert sun hits your camper in the morning). I also like that it is a hardside so when the winds are cranking you can just sit inside and play cards. These campers are solid as shit but kind of heavy (I think mine weighs in just under 500 pounds).
    Let me know if you want anymore photos..
