98-00 Tacomas Only
Discussion in '1st Gen. Tacomas (1995-2004)' started by clickws, Mar 10, 2016.
  1. Apr 13, 2020 at 11:31 PM
    #1761
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    I think sliders are a good preventative for brainless college students or bipeds in general...
    Running Board Man likes this.
  2. Apr 13, 2020 at 11:36 PM
    #1762
    Arctic Taco
    Denali Park, Alaska
    The end cap mod is worth doing, for a couple reasons, it makes for a stronger mounting in the first place, you find out if the horns have any damage- like someone hit the tow hook on anything(seems to happen quite a bit) and then should you opt for a winch install later on, it’s already out of the way!
  3. Apr 14, 2020 at 8:43 AM
    #1763
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    IIRC, the 98-00 did not have this bolt hole. My 99 for sure didn't. The bumper came with 2 plates so that I had to cut off the OEM frame end caps that protrude and have the plates welded in place to resemble what you have stock. It was about 3/8" plate whereas yours looks like not too much.
    ToyotaDriver[QUOTED] likes this.
  4. Apr 14, 2020 at 10:34 AM
    #1764
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Guess that’s what I get for sticking my 2004 nose where it doesn’t belong. :spy:
    Brake Weight[QUOTED] likes this.
  5. Apr 14, 2020 at 11:10 AM
    #1765
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    Yeah but time to make sliders and mount them was not there sadly, really wish I would have had a pair on there. Its crazy how little people care sometimes.
  6. Apr 14, 2020 at 5:35 PM
    #1766
    mataco4wd
    mataco4wd Well-Known Member
    994wd
    Finally stopped being lazy and reset my password lol! Here is one from this weekend in some local woods.
  7. Apr 14, 2020 at 9:17 PM
    #1767
    TacoBike
    Mason
    Favorite part of this thread is forgetting what thread it is and going: Ooh someone posted a photo. Its a 1st gen! Its the same as mine!!
    Really like your bumper with the single cab, looks great.
    mataco4wd[QUOTED] likes this.
  8. Apr 14, 2020 at 10:16 PM
    #1768
    mataco4wd
    994wd
    Same here man! Always love sharing and seeing other builds! Thank you
  9. Apr 15, 2020 at 2:58 AM
    #1769
    rybern
    rybern Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    I'm a believer in paintless dent repair. A good guy can do wonders. I'm extremely particular and I've been AMAZED at what the local gey can do. I never had any issues with paint chipping afterward.
    DON'T just wax your truck. There are so many contaminates on the paint that need to be removed. At the bare minimum, get a Clay bar kit. I like the Miquires kit(~$20) which comes with the clay, spray detailer and a towel. You need all three items. Clay bar will clean your paint. Polish(Maquires #2 is what I use) will bring back the shine and the wax will protect. There are other alternatives to wax that I might try next time.
  10. Apr 15, 2020 at 3:03 AM
    #1770
    rybern
    N Alabama
    Thanks for posting this. I just ordered the 4xinnovations plate bumper(link below), it I have that option I will do it.
    https://www.4xinnovations.com/1995-2004-Tacoma-Front-Plate-Bumper_p_113.html
  11. Apr 15, 2020 at 10:48 AM
    #1771
    TacoBike
    Mason
    Alright, definitely going to be shelling for those dents though D: but its worth it. I'll go for the clay bar, polish and wax, do you know if there are any adverse affects if i don't do all of the panels at once vs doing one fender one day and the hood the next ect. ?
  12. Apr 15, 2020 at 11:33 AM
    #1772
    Winkle99
    Winkle99 Don't Look Back
    David
    CO
    99 XCab 3.4 Manual 4x4 TRD SR5
    Nice to see all the 8N1 Horizon Blue Metallics in this thread. Add another 1999 blue/purple/blurple/periwinkle to the list.
    March 2017 when purchased
    Present configuration
    @rybern - I like the choice of your new 4xInnovations bumper
  13. Apr 15, 2020 at 12:56 PM
    #1773
    rene2193
    rene2193 Active Member
    Rene
    1999 tacoma extended cab TRD 4wd
    F135642F-D363-4EBC-BEA7-D438C5686F13.jpg 1999 new to me
    Lift getting ordered today with the stimulus
    Hamer95USA, Winkle99 and rybern like this.
  14. Apr 15, 2020 at 12:59 PM
    #1774
    rybern
    N Alabama
    You can do that. If you do, then Clay an area and then polish it, then wax. If you clay it and wait a few days before polish, it can have build up on it quickly if you drive it. This build up is what causes things to look like crap when you are polishing. For the record, this has been my experience and I'm still learning. Disclaimer: I'm a machinist, not a professional detailer. ;)
    Watch a few videos on polishing. Make sure it has reasonable feedback. I've been able to do what I've done with a drill and 6" foam wheel(not running wide open). You have to be careful with a drill because it turns a little fast at full speed.
  15. Apr 15, 2020 at 1:00 PM
    #1775
    rene2193
    Rene
    7F075E09-B439-4E48-A515-19D6F5639E9B.jpg Another pic
  16. Apr 15, 2020 at 1:04 PM
    #1776
    rybern
    N Alabama
    Yes, i have come across your truck and studied it a good bit while making my decision. I plan to add custom grill and light hoops but I might get it on there and change my mind. I need to see how you painted your bumper. It looks great. Have you looked at 4" lights? I'd like to get some but don't want to spend too much(just spent a nice chunk on bumper and sliders). My sweet wife will think I'm out of control.
    Winkle99[QUOTED] likes this.
  17. Apr 15, 2020 at 1:06 PM
    #1777
    TacoBike
    Mason
    Alright, that makes sense. Might just start with my tonneau as it is looking more aged than anything else and has few angles on it. Hopefully I can convince my parents to allow me to have a garage space when I do this. I get pollen all over my truck in 30 min just sitting after a wash.
  18. Apr 15, 2020 at 2:14 PM
    #1778
    Winkle99
    David
    CO
    I had the bumper powder coated at a local shop.
    Very briefly I looked at 4" lights at PIAA's website. Lighting is low on my list of priorities. I usually wheel during the day and camp at night so I have little need for extra lights at the moment.
  19. Apr 15, 2020 at 9:49 PM
    #1779
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    Love the truck! Makes me miss stock fenders even more seeing a clean setup like this
  20. Apr 17, 2020 at 11:25 AM
    #1780
    rybern
    N Alabama
    Gotcha. It looks great. Makes sense about the lights.
