98-00 Tacomas Only
Discussion in '1st Gen. Tacomas (1995-2004)' started by clickws, Mar 10, 2016.
  1. Mar 30, 2016 at 4:06 PM
    #161
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  2. Mar 30, 2016 at 4:32 PM
    #162
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    Nice... no idea how I missed this thread...
    1999 3.4 SR5 (swapped in e-locking rear and 4.30's from a runner) too many mods to list here, just click my build (the pic in my sig)
    Most recent shot I have of my truck is only of the rack (picking it up tomorrow)
    but here's a couple shots from Top of the World in Moab from last year's Rock Therapy
    now to kill time reading this thread start to finish
    Saiko, TacoMatt253, boostedka and 2 others like this.
  3. Mar 30, 2016 at 4:37 PM
    #163
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Cool pics!
    ebbs15[QUOTED] likes this.
  4. Mar 30, 2016 at 4:54 PM
    #164
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    What fender flairs are those?
    I had a TMJ before I got the All Pro I have now... Crazy how thin my TMJ was (looked the same minus the d rings, and I didn't have the winch plate as I bought the truck with it)
    the TMJ probably weighed, 40-50lbs... my all pro weighs 90+ easily.
  5. Mar 30, 2016 at 5:19 PM
    #165
    MTgirl
    Weesa
    Bob's secret mod lair
    Jungle Fender Flares. They looked good from a distance but at closer inspection they didn't fit along the body very tight at all. PITA to install too - nothing predrilled, had to blindly guess where the factory holes were. Missed a couple times.
  6. Mar 30, 2016 at 5:38 PM
    #166
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    My TJM weighed in at 76lbs new in Y2K minus the 25 lbs of steel I added along with 45" of weld.
    DustStorm4x4 and ebbs15[QUOTED] like this.
  7. Mar 30, 2016 at 5:53 PM
    #167
    teeRdee
    teeRdee Member
    1998 SR5 TRD 4x4 2.7L
    Looks good! just need new brackets?
  8. Mar 30, 2016 at 5:56 PM
    #168
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    what did you add to it? love the red!
  9. Mar 30, 2016 at 8:40 PM
    #169
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    I'll play, my 98 with a locker, dakars, and OME lift. Sliders and rear bumper in the near future after my custom rocker panel mod:(
  10. Mar 31, 2016 at 1:11 AM
    #170
    thumper72
    thumper72 Well-Known Member
    Jon
    Ogden Utah
    2000 toyota tacoma prerunner v6 auto
    5100's, ome dakar leafs and ome coils, problem solver tie rods, eazycompany ditch light brackets and auxbeam osram 4" led pods, 2014 4runner wheels, 265/70/17 goodyear authority tires, soon to have 50" led bar on roof
    [​IMG] 2000 prerunner with ome coils 881 and dakar rear leafs 5100s all around and just added ditch lights and a luggage rack on the shell has 230k 3.4l auto
    TacoMatt253, DustStorm4x4 and ebbs15 like this.
  11. Mar 31, 2016 at 4:30 AM
    #171
    Blackouts
    Blackouts Well-Known Member
    Las Vegas, NV
    2014 Tacoma TRD Off Road DCSB
    Here's mine. Currently have the skids and fender flares off for paint.
  12. Mar 31, 2016 at 5:16 AM
    #172
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    you don't happen to work for Les Schuab do you? there's a guy who works there that has a red Tacoma, but I wanna say it was more the darker red. anyways, your truck looks good
  13. Mar 31, 2016 at 5:28 AM
    #173
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    How many of ya'll are headed out to Moab in May for Rock Therapy?
  14. Mar 31, 2016 at 6:07 AM
    #174
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    Thanks! Nope that's not me, I get to rock the high school life of fast food
  15. Mar 31, 2016 at 6:26 AM
    #175
    mhorton1911
    mhorton1911 Fightin' Texas Aggie Class of '19
    Mark
    Fort Worth
    2000 2.7 4x4 manual
    Trail Gear front and rear bumper, 5100's all 4 corners, Eibachs, toytec AAL 1980 Ford pickup horn, and lots of battlescars :)
    Trail gear is completely bolt on
  16. Mar 31, 2016 at 6:48 AM
    #176
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Wish I was going.... :pout: I'll live vicariously through you tho
  17. Mar 31, 2016 at 7:35 AM
    #177
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Just put 4.88's and 33's on it. Only pic I've taken since then.
  18. Mar 31, 2016 at 10:03 AM
    #178
    thumper72
    Jon
    Ogden Utah
    how much of a lift is that? and any mods such as pinch welds or cab? nice uca's
  19. Mar 31, 2016 at 10:28 AM
    #179
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Most likely a pinch weld mod. Just smash the fuck out of it with a BFH
    ebbs15 and thumper72[QUOTED] like this.
  20. Mar 31, 2016 at 11:32 AM
    #180
    boostedka
    James
    NM
    Yeah pretty much. I cut the lower part of the weld off first. Then cut a slit into it at the upper part before bending it down. I used some vise grips to start the bend first then just hit it down with a rubber mallet. I also trimmed the fender a bit too. Sprayed it with rubberized undercoating afterwards. Here's a pic of it before I got the 33's installed
