'98 2.4cyl, w/#1 miss code
Discussion in '4 Cylinder' started by danno98toy4, Oct 2, 2013.
  1. Oct 2, 2013 at 5:51 PM
    danno98toy4
    danno98toy4 [OP] New Member
    SR5
    I have a '98 toy tacoma w/120,600 on it. just bought it about 2 mo ago. check eng light came on w/#1 cyl miss code the day after i bought it. thinking it just needed new plugs, i didn't Drive it through the guys front door(yet)
    long story, to make it shorter:
    -changed plugs "NGK"
    -checked coils (good)
    -changed wires to toyota oem's
    -wet and dry checked compression:
    #1:125
    #2:150
    #3:150
    #4:150
    -had toyota flush fuel system
    -cleaned fuel body
    Yes, light keeps coming back on
    I'm wondering if anyone has had the same problem?
    I was told by a mechanic that i brought it to, that it needs a valve adjustment (tight valves) ,but it's 5+ hour job = $500-600+ job
  2. Oct 2, 2013 at 6:51 PM
    5lugger95
    5lugger95 Well-Known Member
    I have a cylnd 2 misfire, i have also replaced all that and still have that "deadspot" when accelerating. Its been bearable but got really bad today.
  3. Oct 2, 2013 at 6:52 PM
    5lugger95
    Im thinking TPS or fuel injector
  4. Oct 3, 2013 at 2:28 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    compression problem to begin with, #1 is low by comparison to other three...and you can do the valve lash setting yourself, just got to remove valve cover and hand crank engine to get all the valves adjusted right, new valve cover gasket when putting together, maybe $25 tops, certainly better than paying someone to do it...it is only four cylinders, that means only eight valves to adjust...
    come on...
  5. Oct 11, 2013 at 11:37 AM
    danno98toy4
    SR5
    Thanks for the reply.Checked the fuel injecters too, seemed fine, not sure what "TPS" stands for though. I was told by another Michanic that it wasn"t the valves(no valve noise) he think it is a bad EGR valve. I was hoping some one would have mentioned that in a reply.
  6. Oct 11, 2013 at 11:46 AM
    danno98toy4
    SR5
    It ain't a chevy...has 16 valves that use shims to adjust the valves(pain in the ass even for a pro)....ask aroud oldphart
  7. Dec 1, 2013 at 6:09 AM
    5lugger95
    My truck has that misfire type feel, like a hicup when accelerating and i know for a fact its the throttle position sensor. But i dont think that would cause low compression?
