98 3.4 liter misfire.
Discussion in '1st Gen. Tacomas (1995-2004)' started by pipelayer_99, Dec 7, 2009.
  1. Dec 7, 2009 at 7:10 AM
    pipelayer_99
    pipelayer_99 [OP] Well-Known Member
    I have searched through past forums for help with this problem but nothing has fixed my misfire yet.
    I got code 0306 for a cylinder 6 misfire. I went home and changed the coil packs, unhooked the battery and went back to get codes checked. It came back still as 0306 so I put a new spark plug in cylinder 6 but still the same issue. Based on the code the 2 other possible problems are a vacuum leak or a bad injector. I have checked all the hoses and they appear to be fine and I would really like to avoid putting in an injector if possible.
    Any other solutions? Any help is appreciated.
  2. Dec 7, 2009 at 7:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    • Faulty spark plug or wire
    • Faulty coil (pack)
    • Faulty oxygen sensor(s)
    • Faulty fuel injector
    • Burned exhaust valve
    • Faulty catalytic converter(s)
    • Running out of fuel
    • Poor compression
    • Defective computer
  3. Dec 7, 2009 at 7:20 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Try switching a wire with the #6 cylinder to see if you get a different code.
  4. Dec 7, 2009 at 8:23 AM
    pipelayer_99
    I switched the coil packs around and still got a cylinder 6 misfire. I checked and there is spark to the plug. I also did the wires this spring as it was misfiring at that time. I thought I fixed the problem but it has come back again and now it's worse.
  5. Dec 7, 2009 at 8:33 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Do you have a compression tester? I would check the compression on that cylinder.
  6. Dec 7, 2009 at 6:18 PM
    pipelayer_99
    I switched the coil pack from cylinder 3/6 to cylinder 1/4 and it still came up misfire cylinder 6 so it can't be the coil pack. I had an old set of plug wires and changed the cylinder 6 wire and it did not help. I also have dual electrode plugs installed, they were done about 6 months ago.
    It acted the same way about 3 months ago and a tank of gas, fuel injector cleaner and a new fuel filter it started running better. I put a new tank of gas and cleaner in today so we'll see if it clears up. I have checked all the vacuum hoses and don't see a bad one.
    I'm thinking it's the injector and of course it's the one under the plenum but I'm about out of ideas.
    This is my wife's truck and she is pregnant so I need to get this figured out. I appreciate all and any help.
  7. Dec 8, 2009 at 12:42 PM
    skipster01
    skipster01 Member
    Iowa
    Tacoma ext cab SR5
    3-4 inch lift, 17"rims procomp tires
    You would be supprised that it may be somthing just as simple as a bad ground. Clean and/or replace the ground cable that goes to the battery cable at both ends. remove on both ends and clean the area where the cable makes contact. seems to be the fastest and easiest fix, if thats what it is. Happened to me. The mysterious miss then disappeard.
    Jeff
  8. Dec 8, 2009 at 1:05 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    Did you check the injector for number 6
    Try using the "stethoscope" method a long screw driver and listen for clicking at the injector. Also check the resistance of the injector and see if it is within specs. Connect a noid light ( a 12 volt light bulb with 2 wires ) , to the injector connector and when you turn the engine over the bulb should flash mimicking the injector pulse.
  9. Dec 8, 2009 at 5:29 PM
    pipelayer_99
    I don't know how to get to the #6 injector without taking the top of the motor apart.
    I put a new PCV valve in just trying to solve it the inexpensive way but that did not help.
    I thought about running Seafoam through it but I'm not sure I want to use that stuff or not.
    I'm running out of ideas. My check engine light was blinking and then went off and has been off all day. I might have to just fork over the money and have someone check it with a computer and compression test because I don't have the tools.
  10. Dec 22, 2009 at 10:34 AM
    mbtaco
    mbtaco New Member
    Santa Fe, NM
    '02 3.4L $WD SR5
    KNN, fabtech front lift
    my service guy said the code for the check engine light was for a misfire in the cylinder 6 (0306 i presume). I have had to change the coil in the number 1 a while ago, where is the number 6 cylinder?
  11. Dec 22, 2009 at 10:35 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Left side (driver) at the firewall. The last one on that side.
  12. Dec 22, 2009 at 12:29 PM
    mbtaco
    mbtaco New Member
    Santa Fe, NM
    '02 3.4L $WD SR5
    Thanks 98tacoma. seems as though there may be more trouble shooting here. As I replaced the 1/6 coil recently (about 2yrs ago at dealer). I guess if they go bad they can miss fire only one of the cylinders?? I'll start with plugs.
  13. Dec 22, 2009 at 12:45 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Make sure you use the double electrode Denso's (OEM plugs).
