98 4x4 2.7L exhaust manifold
Discussion in '1st Gen. Tacomas (1995-2004)' started by Benji G., Sep 14, 2010.
  1. Sep 14, 2010 at 7:30 AM
    Benji G.
    Benji G. [OP] Member
    Benji
    Ruston La.
    03 Tacoma 4x4 2.7L
    2.5" lift
    does anyone know the torque specifications on 98 4x4 2.7L exhaust manifold?
  2. Sep 14, 2010 at 7:32 AM
    98tacoma27
    Ben
    Not Beech Creek
    One moment please....................some will answer your call shortly
    *...cue cheesy elevator music......*
  3. Sep 14, 2010 at 7:42 AM
    98tacoma27
    Ben
    Not Beech Creek
    * ..click..*
    Hello sir, Welcome to TW!! After dubious research, the correct answer is 36 ft/lbs of torque is required for the installation of the Exhaust manifold to the Cylinder head.
    Thank you, and enjoy your day.
    97evergreen likes this.
  4. Sep 14, 2010 at 7:52 AM
    Benji G.
    Benji
    Ruston La.
    03 Tacoma 4x4 2.7L
    2.5" lift
    thank you!!! and what is the best book to buy for maint. and repair?
  5. Sep 14, 2010 at 7:54 AM
    98tacoma27
    Ben
    Not Beech Creek
    This one. The 2003 FSM will be pretty much spot on for your 98. The electrical will differ however. The 96 manual is a downloadable PDF that can be a bear to search. Enjoy.
  6. Sep 14, 2010 at 7:57 AM
    Benji G.
    Benji
    Ruston La.
    03 Tacoma 4x4 2.7L
    2.5" lift
    thanks!!!
  7. Sep 14, 2010 at 8:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    *sitting in thread listening to cheesey elevator music*
    You think Bob would play some bettter tunes.....
    98tacoma27 likes this.
  8. Dec 17, 2021 at 12:07 PM
    Krzykraker
    Krzykraker Well-Known Member
    1998 Toyota Tacoma Base, 2.7L, 4wd, Regular Cab, Shortbed
    This link doesn't work anymore, any idea what book it was? I think mine sucks...
    Also, are you supposed to go back and re-torque like other parts require? Mine is leaking and it was done less than a year ago. I installed a mini header myself and torqued it to what the book said. I was also very careful while installing it. I'm very tedious when it comes to my truck, I wanna make sure it's done properly the first time.
    Thanks in advance!
  9. Dec 17, 2021 at 12:15 PM
    98tacoma27
    Ben
    Not Beech Creek
    It was the factory service manual. There's no reason not to retorque. The heat cycling could have loosened them.
