98 auto tranny shifts a bit rough
Discussion in '1st Gen. Tacomas (1995-2004)' started by odysseus99, Mar 5, 2010.
  1. Mar 5, 2010 at 7:32 PM
    odysseus99
    odysseus99 [OP] Member
    98 taco 4x4 xtracab SR5
    Hi folks-
    I've got a 98 taco 4x4 2.7L auto trans. I just took it to a mechanic for some electrical work, faulty throttle sensor. They test drove it, and told me that it's shifting badly from 1st to 2nd and will probably need a tranny rebuild.
    I bought it with 70k on it, now it has 82k. It has always acted the same. Sometimes, not always, it shifts rough from 1st to 2nd. Sometimes the engine tachs high during the shift (not real high, but noticable) and then it pulls into 2nd. Sometimes it shifts a bit hard, doesn't tach high, but you can feel it hit 2nd kind of hard. Most of the time, it shifts smooth. All other gears are smooth.
    So- do I have a dying tranny, or is this more or less normal for these models?
    I do mostly highway driving- rarely but sometimes grinding on gravel.
    I changed the fluid at 70k with synthetic. Mechanic says that fluid is a bit dirty. He wants me to get a $200 transmission flush.
    What you think? I gotta shell out for a new tranny?
    Is tranny flush a good idea?:cool:
    JG
  2. Mar 5, 2010 at 9:13 PM
    pdxwhiteout
    pdxwhiteout monster taco in the snow
    coty
    pdx
    monster tacoma
    3-inch body lift, 6-inch fabtech lift, 17-inch procomp black alloys wrapped in bfg 37s. trd v-6.
    flushes are designed to get all of the fluid in trans, instead of just whats sitting in the pan, which he probably explained. most are also designed to back flush debree from the internal filters. its pretty expensive but much cheaper than a trans. but if your happy with the way it drives i would suggest simply changing the fluid more often to be on the safe side and dont worry about unless it starts to bother you.
    also check the condition of your motor and trans mounts. they can cause harsh shifting aswell. just a thought. good luck!
  3. Mar 5, 2010 at 9:32 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Against common belief, a hard, quick shifting tranny is optimal. Most unmodified transmission do not shift like that, but rather a leisurely shift thats comfortable for most drivers and passengers. I dont think you have anything wrong...
  4. Mar 5, 2010 at 9:38 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    I'm thinking possibly a slipping intermediate band. I would take it to transmission shop. Mechanics that don't know what they're doing will replace a lot of parts. If you take it to a specialized shop they'll prob just fix what's worn or broken instead of a complete rebuild.
    Tranny flush is always a good idea.
  5. Mar 6, 2010 at 5:43 AM
    odysseus99
    thanks. I'll talk to local shops. Know a good tranny shop in San Jose?
