98 front wheels won't engage when in 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by jdenny, Jan 9, 2014.
  1. Jan 9, 2014 at 9:30 AM
    jdenny
    jdenny [OP] New Member
    Muldrow, Oklahoma
    98 Tacoma 4x4
    I have a 1998 Toyota Tacoma 4x4 Ext cab with 2.7, AT, manual 4x4 lever and manual locking hubs. The problem I'm having is when I engage the 4 wheel drive, the front wheels will not pull. The front driveshaft is turning but wheels are not. I don't know much about the Tacoma 4x4 system as I switched from Jeeps. Any and all information will be appreciated. Thanks all...
  2. Jan 9, 2014 at 9:39 AM
    BamaToy1997
    Bill
    Navarre, FL
    So what you are saying is that if you lift the truck up in the air, your front driveshaft is turning, but the wheels are free, and you can turn them by hand? I am trying to make sure I know what you are talking about exactly, because your Tacoma is all mechanical. There are no electrical switches or motors that could cause this problem.
    I am assuming you have the manual hubs engaged fully.
  3. Jan 9, 2014 at 3:00 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    This happened to me on my old '84 4runner. Couldn't figure out why I couldn't navigate very well in the snow, while 4-wheeling one day. Turned out that one of my free-wheeling hubs somehow got all gunked up with grease, and the mechanism couldn't move into 'Lock' even though the hub dial was completely turned to the 'Lock' position. Front wheels were not under power even though the front driveshaft was turning. One of those hubs might have broken, internally, but I've never seen that happen on an Aisin hub (just happens to Warn hubs, I guess :D )
    Hopefully thats all it is. Otherwise, the diff is likely bad.
    wilcam47 likes this.
  4. Jan 9, 2014 at 11:03 PM
    Indy
    Indy Master of all I survey.
    If there was diff damage hed likely hear a whole lot of grinding. A bad hub is more likely. With an open diff 1 unlocked hub = 2wd.
  5. Jan 10, 2014 at 7:44 AM
    jdenny
    Muldrow, Oklahoma
    98 Tacoma 4x4
    Yes, manual hubs are fully engaged. I did have a bad hub, or at least the part that locks that has the spring behind it. Is there any chance when I re-installed the new lock out this that I may have re-installed it wrong?
    Can someone give me a list of things to check and I would also like to know the vacuum diagram for the 4 wheel drive system and all components. Thanks...
  6. Jan 10, 2014 at 8:44 AM
    Indy
    The outside being in 'lock' doesn't always mean the hub is locked in. If there is a broken part or an incorrect install it might not be working.
  7. Jan 10, 2014 at 8:47 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Did you test the hub after you put it back together? My money is on operator error.
  8. Jan 10, 2014 at 9:00 AM
    Indy
    Lock both sides, 4wd and tranny in neutral. Jack up 1 wheel and turn it. If the hub is engaged you should see the front drive shaft turn. Repeat on the other side. That should tell you which side you're having trouble with.
  9. Jan 10, 2014 at 12:07 PM
    tan4x4
    Rick
    Folsom, CA
    :confused:
    According you your first post, your '4 wheel drive system" is MANUAL. No vacuum lines, fuses, wires, buttons, relays, etc.
    Sounds like your 'bad hub' is still bad.
  10. Jan 10, 2014 at 1:50 PM
    jdenny
    Muldrow, Oklahoma
    98 Tacoma 4x4
    Doesn't the manual systems still have to have vacuum?
  11. Jan 10, 2014 at 1:58 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    No there is nothing else to engage. Turn both hubs and put transfer case in either 4hi or 4 low and that's it.
    wilcam47 and Xbeaus like this.
  12. Feb 4, 2017 at 1:56 PM
    tristen2000taco
    tristen2000taco Member
    2000 3.4L Tacoma
    I'm having the same problem. But auto hubs. The drive shaft spins in 4wd. And in 4lo the back wheels are in Low.but the front wheels won't engage into 4wd. I'm thinking it must be some sort of wiring issue or vaccum issue. Can someone point me in a good direction to start? 2000 taco, stick shift 4x4
  13. Feb 4, 2017 at 2:07 PM
    harper7
    harper7 Well-Known Member
    Gary
    Tulsa/Claremore OK
    00 Imperial Jade 4x4 TRD,01 TRD 5sp
    Here is a good read on ADD and trouble shooting it . Your truck has ADD if it doesn't have manual locking hubs ..... http://www.off-road.com/trucks-4x4/tech/the-automatic-disconnecting-differential-system-19259.html
    I had a newer 4runner and think the ADD was electric and not pneumatic. I haven't had the need to check what the Tacoma is as it's worked like it's supposed to....so far.
  14. Feb 4, 2017 at 2:26 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    When you turn a well greased hub (Asin hub) you hear it engage. Like a spring pops into place. The hub itself is extremely simple. Take them both apart clean and grease. Sometimes water and rust will stop them springing into place. It's that or your diff has blown up. Which would make quite the racket.
  15. Feb 4, 2017 at 2:58 PM
    tristen2000taco
    2000 3.4L Tacoma
    I fixed it with that guys write up, thanks so much man really appericate your help:thumbsup:
  16. Feb 5, 2017 at 2:37 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    The original poster started the thread in 2014, the fella that resurrected the thread has ADD...but good info for future seekers of this issue!
  17. Feb 5, 2017 at 9:08 AM
    harper7
    Gary
    Tulsa/Claremore OK
    @tristen2000taco 's question was on the auto locking
    I have ADD but would much rather have the much more reliable AISIN manual locking hubs and will be a future UPGRADE when I find some.
    Helped a friend rebuild his AISIN's a couple of years ago at 500k+ miles on his 97 taco that he wheeled his arse off in and used this post on mud as a reference...... https://forum.ih8mud.com/threads/rebuilding-aisin-locking-hub-locking-hub-rebuild.149776/
    cruiserguy likes this.
  18. Feb 5, 2017 at 9:36 AM
    Xbeaus
    Beau
    I need to start looking at original post dates when I'm cruising along TW. Haha. I was referring to the original. Anyways..... Good luck!
  19. Feb 5, 2017 at 11:13 AM
    bry838
    oregon
    When i was on the lookout for both my tacos having manual hubs was high on the need to have list! Along with the fully mechanical j shift transfer case too!! That kind of shit just dont need to have vacuum lines and fuckin electrical doodads incorporated into the system...
    When we got the 4 runner we were lucky enough to find one (even the right color)to have a j shift transfer. It seems like they are pretty damn rare, it of course has ADD though dang it. But thats okay i suppose, i don't think the runner ever had a manual hub option anyhow...??
  20. Feb 5, 2017 at 11:43 AM
    harper7
    Gary
    Tulsa/Claremore OK
    Oh yea ...I know for a fact some 3rd Gen 4Runners had them as my x gf had them on her 97 Limited 4rRunner.She hated them as she had to get out to lock them.lol
    3RD Gen 4runners are a direct swap
