98 Pre Runner re-build
Discussion in '1st Gen. Tacomas (1995-2004)' started by amart2009, Apr 22, 2010.
  1. Apr 22, 2010 at 2:00 PM
    amart2009
    amart2009 [OP] Member
    Adam
    Kuwait
    98 Pre-Runner
    I've seen a lot of good advice on this forum. Unfortunately, I've not been so lucky thus far. I'm overseas right now so I'm just acquiring shit for the build when I return. Situation: all piston rings gone, one bent rod, crank shaft is fuqd', as well as all the bearings. I've already located a rebuilt motor with front cover already installed, cylinder heads have been bake cleaned and shot blasted, high quality seals, 3 angle cut valve seats, oil holes have been chamfered and micro polished, and the decks have been milled and surface checked. $1,642 out the door. Deal or no deal?
  2. Apr 22, 2010 at 2:02 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  3. Apr 22, 2010 at 2:12 PM
    amart2009
    Adam
    Kuwait
    98 Pre-Runner
    I put 50,000 on it. Has 183,000 on it now. Piston rings went out on the old lady while she was driving it, dumped all the oil and she kept on truckin'. Sucked, but she didn't know any better. Besides, gives me a reason do dump some green in it.
  4. Apr 22, 2010 at 2:20 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    damn, good luck with it man!
  5. Apr 22, 2010 at 2:23 PM
    amart2009
    Adam
    Kuwait
    98 Pre-Runner
    Yeah, I'm not getting any feedback. What's up with that?
  6. Apr 22, 2010 at 2:27 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    there are no pictures :D
    give it time, its only been a short while
  7. Apr 22, 2010 at 2:46 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Well, basically, need to weigh the pros and cons. What it really comes down to is the condition of the parts you aren't swapping out. You're pretty close to the border line "worth it" in my opinion, but then again, I would also have to hire someone to put the engine in for me as well (time vs money... I'd loose more money doing it myself than paying someone).
    If everything else is in fantastic shape, you'll potentially be able to drive that thing up to 500k+ (with some repairs along the way of coarse, but same repairs for a different vehicle as well).
    But if the trans, suspension, frame, body, or other main components are also about to fail, you're going to end up dumping more into it than it would've taken to buy a lower mileage, later model version.
  8. Apr 22, 2010 at 2:55 PM
    amart2009
    Adam
    Kuwait
    98 Pre-Runner
    Everything else has been well maintained and has no danger of failing at all. And as far as only replacing what is wrong with it, I think that if I'm already going this deep into the motor, why only fix what's broken? May as well re-build the entire motor while I'm in it. Atleast I would think.
  9. Apr 23, 2010 at 5:54 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    I replied on the other post. but I would just replace the motor, and rebuild that one as a project.
    http://LCEngineering.com
