98 Single Cab Manual 2.7L "Smudge"
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mikeyjd, Mar 18, 2015.
  1. Mar 18, 2015 at 6:36 PM
    Mikeyjd
    Mikeyjd [OP] MPG Enthusiast
    Mikey
    Grand Rapids, MI
    97 3.4L 4x4 DLX
    Grill Block, Front Belly Pan, 3 inch lift shims in front, AAL rear suspension lift, Ultragauge Instrumentation, Flush Topper, Full Synthetic Fluids
    Now that we've made through winter and I no longer must rely on the v6 4x4 for it's capabilties, I splurged ($1,000) and got a flat bed 4 banger manual trans 1st gen Tacoma with 170,067.4 miles on the odometer. It's rough around the edges to say the least, but it rides nice. I got it home and dropped the oil and topped up all the fluids. It's a peppy little thing that I think I'll enjoy using this summer.
    Initial 10 mile roundtrip course with Pulse & Glide driving without Engine Off Coasting yielded 37.7mpg uncalibrated on the Ultra Guage. This was after airing the tires to 44psi and removing the passenger wiper. This truck has much taller gearing than the V6, so I found myself wanting to shift early. It doesn't have a tac either which I'll have to add to the front screen on the UG. The UG also powers down when I key off, so I will need to wire in a kill switch in order to EOC.
    I'm excited as this truck is already showing promise and has alot of aero possibilities on the table. First mods to do are:
    Grill Block
    Kill Switch
    Replace brand new rear winter tires with used summer ones
