"98 SR5 FRONT END DAMAGE HELP IN VA"
Discussion in '1st Gen. Tacomas (1995-2004)' started by vatacoma757, Jul 2, 2014.
  1. Jul 2, 2014 at 5:49 AM
    vatacoma757
    vatacoma757 [OP] Member
    Carl
    Hampton,VA
    98 Tacoma SR5
    I am new to Tacoworld.and located in Hampton Va I just got a 98 Tacom Sr5 thats been sitting since 09. I plan on putting it back on the road but will not be doing it myself.I figure someone has been down this road, and can offer me some help on where to find parts or maybe some member knows a local shop/person who can do the do the body / mechanicl work. I will not know if the engine is damaged until its apart. Below are pics anyone interested or have any leads for parts please reply or call 757 506 8351
  2. Jul 2, 2014 at 6:13 AM
    Madjik_Man
    Colorado Front Range
    I have OEM corner lights and turn signals.
    They should fit the 5 lugs.
    I know those are just cosmetic pieces and a small component to your dilemma, but let me know if you want to buy them.
  3. Jul 2, 2014 at 3:02 PM
    Indy
    Indy Master of all I survey.
    That looks like frame damage + cosmetic damage. I'd address the frame and function first and chase fenders later. Unless the wreck penetrated past the radiator there is no reason to take the engine apart to check for damage. As long as its clear drop a running garden hose into the radiator hose and see if it runs correctly. If the engine is toast for some reason, and the frame is a mess, and you need a new front end... you're probably money ahead parting it out and buying a new truck. Early first gen's are *relatively* cheap.
  4. Jul 2, 2014 at 5:59 PM
    vatacoma757
    Carl
    Hampton,VA
    98 Tacoma SR5
    Its been sitting since 09 The radiator is pushed in to the point where its touching the fan assembly Is it ok to just turn it over anyway. Also you say if I need a new front end what parts are you meaning looks like I will need a radiator support ?
  5. Jul 2, 2014 at 6:12 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^You'll want to remove the radiator then. Jerry-rig the radiator hoses together. Will also need to jerry-rig the transmission fluid hoses together.
    From the photos, you'll need a replacement right fender, radiator support, and grille. The inner right fender apron may need rack time at a professional collision shop to be pulled straight (or zipped off and a replacement apron welded in). Frame may be OK but will require inspection up close - can't be diagnosed over the internet. Did the truck rear-end a taller vehicle?
  6. Jul 2, 2014 at 6:23 PM
    vatacoma757
    Carl
    Hampton,VA
    98 Tacoma SR5
    Yes the truck hit another truck taller than this one
  7. Jul 2, 2014 at 6:25 PM
    vatacoma757
    Carl
    Hampton,VA
    98 Tacoma SR5
    just want to know as much as possible before I take it to a shop
  8. Jul 2, 2014 at 6:27 PM
    vatacoma757
    Carl
    Hampton,VA
    98 Tacoma SR5
    Anyone What would be the best placed to look for parts?
  9. Jul 4, 2014 at 10:10 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Try rockauto.com. they're typically cheaper than most places. And Pick N Pull on Sykes Ave in VA Beach might have one in there you can snatch parts from.
  10. Jul 4, 2014 at 11:42 AM
    vatacoma757
    Carl
    Hampton,VA
    98 Tacoma SR5
    Thanks Fenwick do you know any body that does bodywork on South Side or Pen
  11. Jul 18, 2014 at 1:19 PM
    Fenwick1993
    Not Fenwick
    Chesapeake, VA
    Unfortunately I don't know anyone around here for bodywork. I always do my own half-ass body work. 15 yard chain snatch, lol
  12. Jul 18, 2014 at 2:25 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The core support is only $90 buck, each radiator is around a $100. Fenders can be picked up for around $70.
    Are the frame noses still straight? If they are, its very likely that you will not need any frame work.
    Please post some more pics.
    I've put together many Tacoma wrecks over the years. Presently I'm rebuilding an '04 that was much worse off than yours.
    If you have even a slight desire to do the work yourself, you should try it. It's not that hard, just time consuming. take lots of pics as you go. I find it fun and relaxing.
    KO
