98 sr5 steering prob. Help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by olshaner24, Jan 4, 2017.
  1. Jan 4, 2017 at 9:14 PM
    olshaner24
    olshaner24 [OP] Senior Member
    Shane
    Frederick, Maryland
    98 SR5 4x4
    31in Trail Cutters, complete sound system
    Hello. Recently experiencing steering issues with my taco and have no explanation for it. It started a few days ago, while making a turn sharp and when not sharp, at any speed, the steering wheel won't return to center. Fluid level fine. Belt fine. Pump making no noise. See no obstructions in steering. Everything is greased. Not sure what it is. Can it be the rack? Anything else to check?? Any help appreciated. Thanks!!
  2. Jan 4, 2017 at 9:20 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Other then that it drives ok? Could be a binding ball joint, tierod end or bad rack. What color is the P/S fluid?
  3. Jan 4, 2017 at 9:25 PM
    olshaner24
    Shane
    Frederick, Maryland
    98 SR5 4x4
    Yes drives great. Especially for 255,000 mile but must admit the p/s fluid is an ugly brown I noticed tonight. Prob will want to flush but didn't think prob would occur almost overnight. I guess ball joint is possibly issue but just rotated tires and always turn wheels manually to check boots. Seemed normal.
  4. Jan 4, 2017 at 9:32 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Steering effort seems the same?
  5. Jan 4, 2017 at 9:38 PM
    olshaner24
    Shane
    Frederick, Maryland
    98 SR5 4x4
    Seem to be the same at all times besides not returning to center.
  6. Jan 4, 2017 at 10:00 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    I'd start with checking lower ball joints and lower control arm adjusters for tightness.
  7. Jan 4, 2017 at 10:08 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  8. Jan 5, 2017 at 7:50 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    That's a great link Jon. There really is awesome information in here for anyone that wants to diy.
    mechanicjon likes this.
  9. Jan 5, 2017 at 10:08 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Return to center can be a function of the front end wheel alignment as well as any binding that may be occurring. You might consider getting the truck up on jackstands or on a lift/rack to see what the front tires are actually doing as you turn from side to side.
  10. Jan 6, 2017 at 10:50 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I would take the truck to a reliable (spelled R-E-L-I-A-B-L-E) front-end shop and ask them to analyze the front end and tell you what is wrong.
