98 Taco Instrument Cluster Help Needed
Discussion in '1st Gen. Tacomas (1995-2004)' started by candrews86, Feb 7, 2023.
  1. Feb 7, 2023 at 11:02 AM
    candrews86
    candrews86 [OP] Active Member
    The Woodlands, TX
    1998 Tacoma SR5 4x4
    Hey Guys,
    My Tach and Speedometer have quit working, along with the digital mileage read out. The Fuel and Engine Temp gauges are working. I’ve looked at some older threads and it mentioned the speedometer gear but if it was that, wouldn’t the Tach and Digital Mileage still work? It started last night, shut it off, and it started working again so I’m thinking it’s not a fuse, but I’ll check fuses when I get back home. Now back to not working. Any guesses what the fix would be?
  2. Feb 7, 2023 at 1:03 PM
    hamsmash
    hamsmash Well-Known Member
    Sacramento, CA
    00 Tacoma 3.4 4x4 5spd
    Start with the fuses. If those are all good, then look to make sure the connectors on the back of the instrument panel are still connected/making contact (could have oxidation, cutting off the connection).
    candrews86[OP] likes this.
  3. Feb 8, 2023 at 9:45 AM
    candrews86
    The Woodlands, TX
    1998 Tacoma SR5 4x4
    After doing some digging around, I pulled the probe on the Speedometer, and the plastic gears look to be in great condition and not worn at all. Wiring on the switch looked to be fine as well. I checked fuses in the box and none of them are burnt. This problem is intermittent so I’m thinking it may be a contact problem and perhaps i need to take the instrument cluster out, will need to dig around some more to figure out how to do that.
  4. Feb 8, 2023 at 10:20 AM
    hamsmash
    Sacramento, CA
    Does anything light up on the cluster? When I blew the radio/cluster fuse, everything was dark. My speedo and tach didn't work, and the temp and fuel gauges were "stuck" at their last position -- they looked like they worked, but didn't actually move. Inserting the key and cranking the ignition would start the engine, but nothing lit up like usual. Did you check the radio/cluster fuse with a multimeter for continuity?
  5. Feb 8, 2023 at 10:24 AM
    candrews86
    The Woodlands, TX
    1998 Tacoma SR5 4x4
    I haven’t put a meter on it. My blinker signal, bright signal, back light panel still light up.
  6. Feb 8, 2023 at 10:30 AM
    hamsmash
    Sacramento, CA
    Signals are on a different fuse (TURN in the list below).
    If none of the lights are lighting up on the cluster itself, I'd bet it's the cluster (GAUGE in the list below) fuse. Here's a list of the fuses for the internal fuse panel on 98-00:
    18 STA 7.5A Clutch start cancel system, starting system, gauges and meters
    19 4WD 20A A.D.D. control system, four-wheel drive control system, rear differential lock system
    20 GAUGE 10A Gauges and meters, back-up lights, cruise control system, power antenna, power door lock control system, electronically controlled automatic transmission system, starting system, charging system, air conditioning system
    21 TURN 10A Turn signal lights, emergency flashers
    22 ECU-IG 15A Cruise control system, anti-lock brake system, automatic transmission shift lock system
    23 WIPER 20A Windshield wipers and washer
    24 IGN 7.5A Discharge warning light, SRS airbag system, seat belt pretensioners, multiport fuel injection system/ sequential multiport fuel injection system
    25 RADIO 7.5A Car audio system, power antenna
    26 CIG 15A Cigarette lighter, clock, power rear view mirrors, back-up lights, automatic transmission shift lock system, SRS airbag system, seat belt pretensioners
    27 ECU-B 15A SRS warning light, daytime running light system, cruise control system, SRS airbag system, seat belt pretensioners
    28 POWER 30A Power windows
  7. Feb 8, 2023 at 10:54 AM
    hamsmash
    Sacramento, CA
    If you verify the fuse is good and end up needing to take out the cluster, here's a good video showing how. Can have it out in ~15 min.
    Bill-IN-TX likes this.
  8. Feb 8, 2023 at 11:04 AM
    candrews86
    The Woodlands, TX
    1998 Tacoma SR5 4x4
    Thanks for all the help! Much appreciated, will report back with what I find
  9. Feb 8, 2023 at 11:40 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  10. Feb 8, 2023 at 11:50 AM
    candrews86
    The Woodlands, TX
    1998 Tacoma SR5 4x4
    The “Gauge” fuse is still intact and not blown. I’m guessing the only thing left is taking the cluster out and checking for faulty plugs
  11. Feb 8, 2023 at 2:57 PM
    hamsmash
    Sacramento, CA
    Next step is probably to look at the diagnostic steps for the combination meter in the FSM.
  12. Feb 8, 2023 at 7:01 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Check for a loose ground above the fuse box when you take cluster out.
  13. Feb 8, 2023 at 7:05 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    ID ground point
    hamsmash and candrews86[OP] like this.
  14. Feb 13, 2023 at 12:24 PM
    candrews86
    The Woodlands, TX
    1998 Tacoma SR5 4x4
    Cluster is out, all the plugs look fine, no signs of shorting anywhere. Unfortunately do not have a gauge to put them on. Checked the ground on the ID point, looks fine and is snug
  15. Feb 15, 2023 at 9:28 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    The tach, speedo and odometer all are controlled be the odometer module that's held in by a few screws and a plug. You could have a broken solder connection in it.
    Chadley22 and candrews86[OP] like this.
  16. Feb 16, 2023 at 1:21 PM
    Fantastic11
    Fantastic11 Well-Known Member
    1997 3.4L 4WD / 1996 3.4L 5-Lug
    There should be a pin that gives the board its main power 12v+. Try to find the constant 12v+ on the harness side first. Then apply your 12v+ and GND to the board. It should at least light up. If it doesn't, then you may have a faulty cluster after all. I didn't see any in the pics, but these old boards get tiny cracks in the solder joints sometimes, which can be re-flowed.
  17. Apr 3, 2024 at 6:10 PM
    James1911
    James1911 New Member
    Were you able to find the issue? And if so what did it end up being? I’ve got a 1998 Tacoma that is having the same exact problem. First was intermittent, today it went out completely
    Chadley22 likes this.
  18. Apr 3, 2024 at 6:31 PM
    candrews86
    The Woodlands, TX
    1998 Tacoma SR5 4x4
    Never found the issue, but after taking the cluster apart, and putting it back together, it hasn't happened since...
    ControlCar likes this.
  19. Apr 3, 2024 at 9:31 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Can’t Tell You how many times this ‘taking apart then putting back together’
    has solved issues in my experience
    Awesome
  20. Sep 8, 2024 at 2:59 PM
    Chadley22
    Chadley22 Well-Known Member
    Chad
    Tacoma
    It must have been a loose connection somewhere, that you secured.
    Mine has quit working for just a minute, 2 different times in the last 2 years.
