98 tacoma 2.7 runs when cold but engine dies when hot
Discussion in '1st Gen. Tacomas (1995-2004)' started by BrandonGP, Jan 4, 2017.
  1. Jan 4, 2017 at 11:26 AM
    BrandonGP
    BrandonGP [OP] Member
    LIST of things verified...
    New fuel pump and filter
    All sensors checked out ok
    Clean throttle body
    Verified spark on all plugs and coils test good
    Engine with run for about 5 minutes cooled...once it gets to normal running temp it will start skipping then die. Engine will not restart untill it cools off. Im showing a p1300 code but when engine dies the fuel trims will be -100%. Im thinking i have a bad ecm... any ideas would help thanks.
  2. Jan 4, 2017 at 11:32 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    check engine light?
  3. Jan 4, 2017 at 11:37 AM
    BrandonGP
  4. Jan 4, 2017 at 11:39 AM
    BrandonGP
    For bank 1 o2 sensor heater. Surely that wouldnt cause this problem?
  5. Jan 4, 2017 at 11:44 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    98tacoma27 likes this.
  6. Jan 4, 2017 at 11:46 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Sounds like cold start circuit problem. I wouldn't start throwing money at other things like fuel PSI etc. yet.
  7. Jan 4, 2017 at 11:46 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    It would cause fuel control issues. Not enough to do what your describing. The sensor heater is only used as the exhaust warms up. After a few minutes, the heat from the exhaust keeps the sensor at temperature.
    When does your issue happen, at idle, acceleration? Can you tell what kind of stutter it is, from air or fuel starvation?
  8. Jan 4, 2017 at 11:48 AM
    98tacoma27
    Ben
    Not Beech Creek
  9. Jan 4, 2017 at 11:57 AM
    BrandonGP
    It seems from my own senses that the engine is extremely lean when it shuts down. When i try to restart... it will try to start but wont. Engine will start to stumble for 5 seconds or so then shuts down. No resart till completely cooled back down.
  10. Jan 4, 2017 at 12:02 PM
    BrandonGP
    Engine will not run long enough to drive on the highway. Just long enough to move it from my shop.
  11. Jan 4, 2017 at 12:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  12. Jan 4, 2017 at 12:06 PM
    Caligula
    Los Angeles, CA
    No codes other than the o2 heater? Nothing in pending? Is it possible for you to take a snapshot of the PID data as the car is dying?
    I'm going to suggest something on a fluke. Check your idle air control, at idle there should be minimal port vacuum from where it draws air immediately before the butterfly. Just a thought.
  13. Jan 4, 2017 at 12:11 PM
    BrandonGP
    Ive got a new obd scan tool ordered. Should be here friday. The only code is p1300. From my old scan tool.
  14. Jan 4, 2017 at 12:16 PM
    Caligula
    Los Angeles, CA
    Bro, that is an ignitor code, not a o2 heater code. What model is your truck?
  15. Jan 4, 2017 at 12:19 PM
    BrandonGP
    P1300 and the o2 code what should i should have sayed.
  16. Jan 4, 2017 at 12:24 PM
    Caligula
    Los Angeles, CA
    Well the p1300 is what is shutting down the engine. A non-functional coil or ignitor will cause a misfire condition by sending unburnt fuel through the catalytic. The main priority of the ECU is fuel control and to protect the catalytic.
    You may end up just replacing the #1 coil when all is done. Though first check all the leads for it, insulation, use a multimeter between the plug to its corresponding ground and source on the Ecu. When the engine is warm you want to ensure these connections are good, and the ignitor is getting source voltage. If you have a known good part you can just swap it out and see what happens, otherwise do the diagnostic strategy I said above.
  17. Jan 4, 2017 at 12:27 PM
    98tacoma27
    Ben
    Not Beech Creek
    https://www.tacomaworld.com/threads/2-7l-will-not-start-when-hot-any-ideas.168253/page-9
    This is a common issue of the 2/3rz platform. It could be anything from a charcoal canister to the ECT. I would suggest checking all grounds, wires, connections then appropriate sensors, relays, injectors and VSVs before delving into the big ticket ($) items.
    There is only one common issue I've seen to fix this issue ... the charcoal canister (mentioned it the thread above) ... and it isn't a guaranteed fix.
    :humble:
  18. Jan 4, 2017 at 12:27 PM
    T4RFTMFW
  19. Jan 4, 2017 at 12:32 PM
    Caligula
    Los Angeles, CA
    This is getting a little queer.
  20. Jan 4, 2017 at 1:24 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Lmao jajajaja
