98 Tacoma 2.7L won't start
Discussion in '4 Cylinder' started by haroldpo, Jan 23, 2013.
  1. Jan 23, 2013 at 4:30 PM
    haroldpo
    haroldpo [OP] Member
    98 tacoma 2.7L
    The check engine light start flashing and it started running rough, but made it home. Next day it would not start. Things i have checked or replaced.
    Since toy decided not to put a fuel test port on the fuel rail i checked the fuel pressure at the fuel filter, all OK
    Have fire to all plug wires, installed new plugs anyway.
    Cam sensor had oil all over it so i installed a new one, not easy, no change.
    Cleaned TB
    The codes where PO300/
    PO302/PO304 cylinder #2&#4 misfire.
    1/2 tank fuel
    Compression is 175/180/176/180
    All fuses is good.
    Still the truck will not start, where should i look next?
    Truck has 180,000
  2. Jan 24, 2013 at 4:24 PM
    haroldpo
    98 tacoma 2.7L
    Bamatoy1997 you out there?
  3. Feb 1, 2013 at 10:00 AM
    haroldpo
    98 tacoma 2.7L
    Pulled it to a repair shop and he said i had bent valves, jumped time he thought. Wants $1800 for repair. I don't see how a bent valve would let me have 175-180 psi on all cylinders. Pulling it home tomorrow.
  4. Feb 9, 2013 at 5:58 AM
    haroldpo
    98 tacoma 2.7L
    Fixed
  5. Feb 11, 2013 at 10:02 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Well, what was it, and what did you do :confused:
  6. Feb 13, 2013 at 7:41 AM
    haroldpo
    98 tacoma 2.7L
    Just think, 188 views and no help offered.
  7. Feb 13, 2013 at 1:24 PM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    The 4cyl section doesn't get checked much. Better luck can be had in the 1st Gen section.
    Glad you got it all sorted though.
