98 Tacoma air bag light
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98toyota4x4, Jun 19, 2023.
  1. Jun 19, 2023 at 11:14 AM
    98toyota4x4
    98toyota4x4 [OP] New Member
    Riggy
    Hi All, I'm new here, Rick is the name. I'm the original owner of a 98 Tacoma 4X4 with 375, 000, the air bag light was flickering on & off at some point, its now on fulltime. I have a code reader for the modern vehicles, but not this year. I'm not sure if its a glitch or actual issue with air bag? Id like to hear how you fixed your situation. Thanks in advance!
    UPDATE! 6/29/2023 My problem is fixed. it was the clock spring in the steering column. Thanks!
  2. Jun 19, 2023 at 2:47 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    You'll need to pull the codes in the airbag module. With most readers you should be able to select the module. Mine was throwing a code that the airbag computer failed, new (used) computer fixed it up
  3. Jun 29, 2023 at 10:23 AM
    98toyota4x4
    Riggy
    Thanks! all fixed now. worn out clock spring.
