98 Tacoma AT shifter won't move & no start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Surfishsail, Apr 1, 2022.
  1. Apr 1, 2022 at 1:07 PM
    Surfishsail
    Surfishsail [OP] Member
    1998 Tacoma 4x4 V6
    The other day I went to start my truck and the brake petal went to the floor & it wouldn't shift into gear...brake line rusted...leak!!!...replaced brake lines and purged...engine started great... brake pedal felt good...shifter shifted into gear...seemed back to normal...
    a few days later...turned key and no start...just a click...& shifter wont move into any gear...brake pedal hard...
    checked battery charge - good - starter bad?
    last year I rebuilt the starter...replaced contacts but didn't replace solenoid plunger...it looked good? connections to starter look good...
    Why won't it shift into gear? neutral safety switch? something with braking system?
    Im beyond frustrated...I'm not a mechanic...but i'm mechanical...lol...I like to do my own work because I know I will take the time to do it right...just can't figure this one out...
    Black DOG Lila likes this.
  2. Apr 1, 2022 at 1:16 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Shifter bushings probably broke
  3. Apr 1, 2022 at 1:35 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    you can stick a piece of metal/hard plastic in the slot above the P position on the shifter. this will allow you to take it out of Park and put it in Neutral to test.
    found this for a T4R but same thing. you can see where the slot is on the plastic above the Park position.
    actually I bought bushings a while ago but haven't put them in yet so I'll be using this too :)
    MalinoisDad likes this.
  4. Apr 1, 2022 at 1:51 PM
    Surfishsail
    1998 Tacoma 4x4 V6
    Thank you...but no start in neutral either...:confused:...
  5. Apr 1, 2022 at 2:07 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    just "click-click" like bad battery? terminals OK on battery?
  6. Apr 1, 2022 at 2:27 PM
    Surfishsail
    1998 Tacoma 4x4 V6
    One click...battery terminals clean & tight...i can hear starter solenoid plunger "plunging" when I turn key in ignition...its just strange it will not allow me to shift it into any gear without popping off the cap you mentioned...normally with foot on brake pedal & ignition turned... the shifter will move into any gear...i feel like it has to do with the brake line failure? Like something locked?
  7. Apr 1, 2022 at 4:49 PM
    Black DOG Lila
    Virginia
    Has the battery been load tested ?
    I'm not talking voltage measured.
  8. Apr 3, 2022 at 12:25 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    could be a fuse if pressing the brake pedal does not engage the Park release?
  9. Apr 3, 2022 at 12:59 PM
    Surfishsail
    1998 Tacoma 4x4 V6
    Update: I got it started (bad ground)...however it still will not come out of park...im thinking it may be the shift solenoid? When I got it started the E light came on...then I disconnected the neg. terminal to repair it...& E light is gone...for now...
  10. Apr 3, 2022 at 5:28 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    Area51Runner likes this.
