98 tacoma frame swap motor mount brackets
Discussion in '1st Gen. Tacomas (1995-2004)' started by steele98, Jun 12, 2016.
  1. Jun 12, 2016 at 10:38 AM
    steele98
    steele98 [OP] New Member
    max
    1998 tacoma 4x4 extended cab
    Hey everyone im new to the forum but I have visited it often for answers to many problems I have come across. I have one new problem that I just cant seem to find the answer to. I recently bought a 1998 Tacoma 4x4 extended cab and wouldn't you know it had a rusted frame. I purchased a used from from a guy off of craiglist and I had it sand blasted and powder coated.
    I started the swap Friday and everything was going smoothly until yesterday when I went to set the engine and trans on the new frame and the motor mount brackets appear to be a half inch further back than the ones on the old frame thus keep me from lining up the trans mount on the crossmember. My truck is a 2.7 5 speed and I believe that the guy I bought the frame from told me the frame was from a truck with a 6 cylinder engine and possibly an auto trans (not sure on that part). Is there any kind of different mount or bracket that I can use to make this work? I really don't want to have to cut the brackets off the freshly powder coated frame to move them forward. Thanks for any help resolving my issue.
  2. Jun 12, 2016 at 12:30 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    cant you just unbolt the 6 cylinder motor mounts and bolt on your 4 cylinder ones?
    if not then yes you will need to cut those off and swap them with the ones from your old frame
    just mock up the full setup, engine, tranny, drivetrain, to be sure everything fits right, then get it recoated because I wouldn't be surprised (and most likely will) if the tranny mounts need replacing as well
  3. Jun 12, 2016 at 12:34 PM
    steele98
    max
    I was wondering if they would interchange like that but I don't have a 6 cylinder engine to know for sure. It appears that moving the perches on the frame is going to be the only option. It sucks but im to far into it to back out now. Thanks for the reply
  4. Jun 12, 2016 at 12:38 PM
    keakar
    karl
    louisiana
    well im pretty sure the v6 tranny mounts wont be close to whats needed for yours and the full mockup is what you want to do because im sure there are going to be lots of other things needed to be tweaked or adjusted with a BFH (big "f" n hammer) :sawzall:
    besides, its going to be a lot easier to work on it all without the body in the way
  5. Jun 13, 2016 at 1:31 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If you have the clearance and it is only the transmission mount .
    i would modify the cross member to work .
    To me that would be much easier then moving the engine mounts .
    If need be build a whole new cross member
  6. Jun 17, 2016 at 11:00 AM
    project_baja
    project_baja New Member
    Kayne
    2003 tacoma
    I'm having the opposite of this my motor (2.7)has a cracked head and so I found a 98runner with a 3.4 so I was wondering if it is just like a drop in job
  7. Jun 17, 2016 at 12:56 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    It is going to be more then just a drop in swap
    Not impossible but not plug and play
