98 Tacoma is my FIRST CAR! I have questions...
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98isgreat, May 8, 2025 at 3:05 PM.
  1. May 8, 2025 at 3:05 PM
    98isgreat
    98isgreat [OP] New Member
    Thursday
    Aurora
    98 Green Tacoma
    Hello everyone! I recently purchased an absolutely beautiful 1998 Tacoma from a family friend. Almost no rust, engine look beautiful, the bed is in amazing shape and she has a cap!!! I feel so insanely fortunate BUT I'm not a car person... I wanted to reach out to some seasoned Tacoma owners to see if anyone had some off the bat tips for keeping her in tip top shape! I live somewhere where the roads are salted to the MAX and so one of my first orders of business is going to be getting seat covers and floor mats. Can anyone recommend a good brand or website? I'm so excited for this next chapter!
    ab_1280 and RustyGreen like this.
  2. May 8, 2025 at 3:15 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Welcome to the great TW!
  3. May 8, 2025 at 3:17 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check the frame really good for rust
    And welcome to TW
  4. May 8, 2025 at 3:18 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    Congratulations on the truck :thumbsup:
    The first order of business is to check the frame for and protect it from rust.
    These trucks don't wear out with reasonable care - they rust away.
  5. May 8, 2025 at 3:20 PM
    98isgreat
    Thursday
    Aurora
    98 Green Tacoma
    The frame looks really good! It has been cared for really well so the rust is currently minimal. I know rust is a pretty common problem with these so feel free to shoo me off to google to research as I'm sure you all are tired of talking about it, but do you have any tips for rust prevention?
    RustyGreen and Steves104x4 like this.
  6. May 8, 2025 at 3:42 PM
    SpencerTacoSC
    SpencerTacoSC Well-Known Member
    Daniel
    2004 Tacoma 4x4 V6
    Any thick-film rust inhibitor is good, as long as you replenish it regularly (think a light touch-up once a year, and maybe have a shop redo it every ~5 years). You have to make sure to coat the inside of the frame as well.
    Fluid Film, Woolwax, and Waxoyl are the big three recommendations - Fluid Film & Woolwax are both lanolin-based, and are... basically compatible, I don't think Waxoyl is compatible with the other two, but it seems to be somewhat superior and require a little less maintenance. On the other hand, I don't think you can really DIY Waxoyl (ready to be proven wrong), so if that's a dealbreaker, steer clear.
    The other big maintenance item that doesn't show up in a maintenance schedule is the lower ball joints. Lots of folks will say if in doubt, change them out. I would say check them. You (or a mechanic, if you're not mechanically inclined) can do it very quickly, and if they're still in spec, there's no point in changing them out.
    https://www.youtube.com/watch?v=bu2rQMxXV2M
    There's a proper way I do it with a dial indicator (Maximum play .002" combined up and down) and a torque wrench, but honestly both ways work well enough, especially if you're not doing heavy trail rides.
    RustyNut1996 and RustyGreen like this.
  7. May 8, 2025 at 3:46 PM
    bwise
    bwise Well-Known Member
    Other than rust:
    Replace the lower ball joints. They fail and when they do your front tire will slide under the vehicle it’s bad. Plenty of YouTube videos on how to do this task if you are handy. Otherwise get these replaced ASAP unless you know of the last time they were done.
    Get the timing belt replaced. At least for the 5VZ-FE (The V6) if the belt snaps your car won’t run. In other engines if the belt snaps you’ll destroy the engine. Replace every 90k miles or 9 years.
    Everything else is pretty standard. Check and replace if needed:
    - Oil and filter
    - Engine air filter
    - Battery
    - Power Steering Fluid
    - Brake Fluid
    - Transmission Fluid
    - Rear and front differential fluid (only front diff if 4x4)
    - Transfer case fluid (if 4x4)
    - Coolant
    - Spark plugs
    Also grease the drive shaft if that hasn’t been done.
    You should be able to find the maintenance intervals for all this stuff in a manual in a glove box.
    Whenever I get a new car I usually at least do an oil/filter change and do as much of the list above as I can afford or as needs done.
    seriously though do not skimp on those lower ball joints it’s unsafe for you and others one the road. I also wouldn’t skimp on the timing belt and engine oil/filter change. Everything else you could probably get away with just depends on how long you want it to last
    RustyGreen likes this.
  8. May 8, 2025 at 4:28 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Welcome!!!!!!
    as seasoned member, OldSilver, says
    These tacos are more like a project vehicle
    Meaning
    As long as you wrench on her/maintain her……you should get satisfaction
    tons of help here
    Couldn’t of made mine(kids 1st veh) roadworthy without TW
    Cheers!
  9. May 8, 2025 at 4:38 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Welcome!!!
    Get the ball joints checked or replaced. Then do a lot of reading here. There’s a a lot of good info on this forum and a lot of people willing to share knowledge.
    Cheers!!
  10. May 8, 2025 at 4:39 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
  11. May 8, 2025 at 4:44 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    Welcome and i hope you enjoy your truck. Nobody answered the floor mats and seat covers question. My floor mats are still good so not sure and I purchased my seat covers at Walmart dickie's brand. They are ok nothing special but they protect my nice seats. Have fun be safe. I'm kinda pragmatic with my taco.
    98isgreat[OP] likes this.
  12. May 8, 2025 at 5:04 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Get rid of it......its just a money pit
    Moonrman, rocknbil and Parkvisitor like this.
  13. May 8, 2025 at 5:08 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    rocknbil, Parkvisitor and RustyGreen like this.
  14. May 8, 2025 at 5:17 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    True but at least welcome the new member
    ControlCar likes this.
  15. May 8, 2025 at 5:28 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    @O'Silver_Taco has a point in his comment. :D This first thing many new Taco owners want to do is go for mods like lift kits (or drop kits,) steroo systems, new bumpers and such. Your truck is 27 years old, even if well maintained at the very least rubber is hardening/decomposing and you'll spend a ton of money just in upkeep and maintenance, it is almost never ending. As mentioned above put your money into maintaining it and keeping it in good shape and it will give you a long life of service. Welcome to TW and dig around here, lots of info on just about anything you'll need to do.
  16. May 8, 2025 at 5:53 PM
    ControlCar
    Steven
    Sugar Land TX
    Expertly Well Said ^^^^^
  17. May 8, 2025 at 6:33 PM
    98isgreat
    Thursday
    Aurora
    98 Green Tacoma
    Ah! Y'all are the best! Thank you for all the tips... I will definitely get the ball joints checked but no I will not be getting rid of her :)
    I will also check out the forum for 1st gens and thank you for the tip on seat covers!
    I hope to post a pic when I pick her up next Thursday but until then I'll keep digging here for info!
  18. May 9, 2025 at 3:20 PM
    Pbfender15
    Pbfender15 Well-Known Member
    multiple 1st gens
    Also from the salt belt.... and after three completely rotted frames I found the right preservation product. Get the frame coated with Waxoyl (or do it yourself). This depends a bit on any previous coatings, but Waxoyl works really well. I've had it on mine for 8 years. One product goes on the outside surface and a different product goes in the inside of the frame.
    There are shops that do it, but it's easy to DIY either with a air compressor or they have aerosol cans.
    https://www.waxoyl-usa.com/
    Good luck -- post pics of truck..
    Steves104x4 likes this.
