98 tacoma key won't turn off
Discussion in '1st Gen. Tacomas (1995-2004)' started by kai131tacoma, Jan 30, 2014.
  1. Jan 30, 2014 at 5:47 PM
    kai131tacoma
    kai131tacoma [OP] Member
    Kai
    Hawaii
    02 tacoma 4x4 extra cab
    3" lift, window tint, pro comp rear shocks
    My brother has a 98' tacoma 4x4 and the key won't go to lock and pull out. He can put the key in and start the truck and turn it back to acc but then it won't go into lock and pull out. We've tried switching between gears and making sure it's in park. If we disconnect the battery, the key comes right out. Any solutions?
  2. Jan 30, 2014 at 7:35 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    definitely sounds like the computer (or whatever controls the has-to-be-in-park-to-pull-key-out) is malfunctioning.
    My friend had a similar situation. None of his brake lights work, it was very hard to take the car out of park, and he had a very hard time turning the car all of the way off when in park. Turns out the brake pedal sensor was not seated correctly.
