98 tacoma new battery, and good starter wont start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shupedude, Feb 17, 2020.
  1. Feb 17, 2020 at 8:53 PM
    Shupedude
    Shupedude [OP] New Member
    So I first had the issue when I drove to the gas station and all was well. When I went to leave my truck wouldn't even turn over. So my dad come by to help me out and it wont jump start. So we towed it and went to working out the problem. I've taken out the starter and tested it. It's good. I replaced the battery and put the starter back in at the same time. It started up and so I turned it off and cleaned up. I started it again and all was good. I went to the gas station to get gas and when I went to leave no start. Exact same problem. This time I tried leaving my dads truck hooked up for 30 min. No start. I tried disconnecting the battery for 30 min. No start. I'm really at a loss. I'm starting to think about the ecu and the starter switch.
    wilcam47 likes this.
  2. Feb 17, 2020 at 8:59 PM
    Taco Roofer
    Taco Roofer Well-Known Member
    Noah
    Southern Oregon
    2004 Tacoma 4dr 4x4
    The work beast and weekend warrior rig.
    Stop going to that gas station...
    :thumbsup:
    det107, suaveflooder and cruiserguy like this.
  3. Feb 17, 2020 at 9:00 PM
    Taco Roofer
    Noah
    Southern Oregon
    2004 Tacoma 4dr 4x4
    Sorry lol... in all seriousness.
    Is it draining the battery?
    suaveflooder likes this.
  4. Feb 17, 2020 at 9:04 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    Check you key tumbler. Could be really warn and not trigger relay for the starter solenoid.
    Do you have a multimeter?
    det107 and suaveflooder like this.
  5. Feb 17, 2020 at 9:09 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Does it click when you turn the key? I'm suspecting a starter solenoid.
    det107 likes this.
  6. Feb 17, 2020 at 9:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    A list of a few things to look at
    1. Ignition Switch
    2. Park Neutral or Clutch Safety Switch
    3. Starter Relay
    4. Starter (Hot vs Cold) I’ve seen some starters fail when they are heat soaked from engine temps.
    5. Battery. (Not likely as you say it is Good)
    Hope you get it figured out soon.
    det107 likes this.
  7. Feb 17, 2020 at 9:13 PM
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    Check your grounds going to the block. I bet one of them is either loose or corroded.
    det107, Wyoming09 and TnShooter like this.
  8. Feb 17, 2020 at 9:24 PM
    Shupedude
    I was actually thinking the same thing about the gas station.
    But yes I have a multimeter. Are you talking about the key or the ignition key hole?
    I havent checked the voltage on the battery since I got back today. I gonna check it tomorrow.
    There is no sound at all except from the fuel pump priming the engine. Also dash lights all come on like normal.
    I have also checked the starter relay, neutral safety switch and the starter (both hot and cold).
    Taco Roofer likes this.
  9. Feb 17, 2020 at 9:29 PM
    Shupedude
    What are you referring to exactly?
  10. Feb 17, 2020 at 9:31 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Do you have a manual or auto?
    Xbeaus likes this.
  11. Feb 17, 2020 at 9:53 PM
    jdmstuff
    Derrick
    There are two ground wires running to the engine block. One goes from the firewall to the back of the right bank of cylinders. Check to make sure none of them are loose or the wire is corroded. You can also just jump the negative terminal from the battery directly to the engine block and see if it cranks. If it does, it's one of your ground wires for sure.
    det107 likes this.
  12. Feb 18, 2020 at 1:45 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Possible with a loose ground the way the vehicle sits things move around to cause a open circuit.
    Pulling the cables off the battery and installing might have moved things again enough to make contact .
    Since you don`t mention just what year the cables might be corroded under the insulation from old age.
  13. Feb 18, 2020 at 9:02 AM
    Shupedude
    Ok I'll check those too. I have a 98 tacoma 4wd with auto transmission
  14. Feb 18, 2020 at 9:49 AM
    Toyko Joe
    What's the battery voltage?
    What's the battery voltage when it's running?
    Bad alternator could cause you to have a battery drain.
    Do you get accessories or dashboard lights when you turn the key before you try and start it?
    Taco Roofer and suaveflooder like this.
  15. Feb 18, 2020 at 9:57 AM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    You have a lot of good info here. If you are just killing the battery over and over again, it’s probably the alternator. That would be the first place I would start.
    after that, the ignition would be my second thought
  16. Feb 18, 2020 at 10:00 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Try starting it in neutral, maybe the safety switch is bad.
  17. Feb 18, 2020 at 8:07 PM
    Taco Roofer
    Noah
    Southern Oregon
    2004 Tacoma 4dr 4x4
    I'm thinking you might have nailed it here...
    Next time you get it started, take the positive cable off of the battery. If it dies, you need a new alternator.
  18. Feb 18, 2020 at 8:09 PM
    Taco Roofer
    Noah
    Southern Oregon
    2004 Tacoma 4dr 4x4
    This would be another easy test to rule out one more thing...
  19. Feb 18, 2020 at 8:12 PM
    Taco Roofer
    Noah
    Southern Oregon
    2004 Tacoma 4dr 4x4
    Shupedude... If there is one thing I have learned over the years building cars and solving mechanical issues, its always start with the simplest things first. I always start with simple tests, fuses, wires etc... they build these things to go out before you kill something bigger.
