98 tacoma no crank no interior lights any help would be appreciated
Discussion in 'Technical Chat' started by Steele2016, Nov 14, 2021.
  1. Nov 14, 2021 at 4:58 PM
    Steele2016
    Steele2016 [OP] New Member
    1998 tacoma 4wd
    I got a 98 tacoma 4 cyclinder I recently bought I brought it home it had a broken ball joint anyway when I got home I put a jump box on the battery just dying to hear the motor hoping it was even good anyway I turned the key over nothing so I kept messing with the key finally dash lights interior lights came on and it fired right up motor sounded like a sewing machine then I shut it off really quick and couldn't wait to fix the ball joint long story short it hasn't ran since it won't do anything when I turn key over plus no interior or exterior lights only thing shows is oil light and check engine light I put a test light on the wire from ignition to starter it lights up when you turn key over so I ran jumper wire from ignition switch to starter its turning over and getting power to coils but nothing coming out of coils I tried checking coils with multimeter but not sure on the resistance or ohms it supposed to have I also by passed nuetural safety switch checked all fuses and relay if anyone can help it would be greatly appreciated thanks
  2. Nov 14, 2021 at 4:59 PM
    Tacotsubo
    Tacotsubo Mediocre at best
    Kevin
    San Antonio
    2019 MGM DCSB TRD OffRoad
    You may want to change the title of your post.
    The word HELP is for people in immediate need of assistance in emergency situations.
    tcjacado and Tacospike like this.
  3. Nov 14, 2021 at 8:43 PM
    Steele2016
    1998 tacoma 4wd
    Okay let me figure out how to change it I'm new at this lol
  4. Nov 15, 2021 at 4:36 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    So you were getting power to the starter but it wasn't doing anything so you ran a jumper to it and then it cranks but doesn't start? Seems kinda odd that the starter would work with a jumper wire but not from the factory wire if it had power on the factory wire.
    I've attached the relevant wiring diagrams below, if you can provide more information I can maybe figure out how/what you need to test next.
  5. Nov 16, 2021 at 8:07 AM
    Steele2016
    1998 tacoma 4wd
    Yeah man it's weird for sure I put another ignition switch in last night now I can get it to turn over but still don't start but while it's cranking over I put my foot on brake pedal and it kills it let off brake pedal continue cranking over lol I've never ran into anything at all like this man seems like alot of messed up wiring to me I still got no dash lights headlights nothing inside while on acc except a buzzing sound I think it's coming from fuse box under the hood
  6. Nov 16, 2021 at 11:10 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    From your initial post you make it sound like you bought the truck without starting it or driving it, got it home and when you tried to start it is when the problems began. If that’s the case you you should contact whoever you bought it from and get as much information about the problems with the truck as you can. That might at least give you an idea of what all is going on with it and what direction to take. There may be a lot of problems with this truck.
  7. Nov 16, 2021 at 11:15 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I think I would want to check voltage drop on main powers and grounds before going down a rabbit hole on anything else, it sounds like a main power or ground issue to me.
  8. Nov 20, 2021 at 5:14 AM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Remove each relay one at a time in the engine compartment, Clean the pin connections and replace the relay. Physically check each and every fuse to see if they haven not blown.
  9. Nov 20, 2021 at 5:22 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Wiring all by it's self generally does not go bad it usually needs help from a hack. Look for some thing that has been tinkered with taped up etc. While you are at it remove and clean the battery cables and posts to rule that out.
  10. Nov 20, 2021 at 1:34 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Time for a Meter a test light only tells you so much..
    Have you pulled any codes ??
    Fresh Gasoline ? Some goes bad really fast.
    I really hope the price was a few hundred dollars.
