'98 Tacoma purchase questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by DeeGee, Jun 24, 2010.
  1. Jun 24, 2010 at 8:19 AM
    DeeGee
    DeeGee [OP] New Member
    Howdy! First post here.
    I'm going to buy a '98 Tacoma 4x4 Xtra cab from my uncle. The truck is in good shape with 155,000 miles. He's the original owner and has faithfully done all the maintenace. 4 cyl, AC, matching canopy, bed liner, manual trans. KBB gives a private party price of around $4200. Does this sound about right?
    KBB lists 2.4 and 2.7 liter engines for the truck. Did Toyota offer two different 4 cyl's?
    Anything in particular I should check for or be cautious of? I don't know much, so don't know what questions to ask.
    Thanks!
  2. Jun 24, 2010 at 8:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, the 2.4 typically came in the 5-lug (non-4x4 suspension). The 4x4 suspension trucks will have a 2.7 or 3.4 (V6). The one thing to look at on that particular model/year is the frame. There is a huge frame rust issue going on right now.
  3. Jun 24, 2010 at 8:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
  4. Jun 24, 2010 at 9:06 AM
    scocar
    scocar Patron of the Farts
    ^^^ Rust is usually an issue in areas where there is a lot of snow and salt is used on the roads. Where has this truck lived? If you search this site for "frame rust," you will quickly learn a lot about this issue and the frame replacement/buyback programs. I do not have direct expereince with this issue. I belive it is stickied under 1st gen.
    Is the suspension original? Shocks and springs? These are notorious for weak OEM design, and at that mileage, they are likely toast if he hasn't replaced them. Seach the Suspension threads for "leaf springs," and you will also learn a lot quickly. Basically, it makes sense to replace them with superior aftermarket parts. Many choices are available depending on your budget and how you plan to use your truck. In fact, the variety is staggering. I do have direct experience with this.
    I think these are the two big issues to be aware of.
    Caution: you are about to learn a lot quickly and spend the next 72 hours on this site! It's awesome! :pccoffee:
    Good luck!
  5. Jun 24, 2010 at 12:36 PM
    DeeGee
    Thanks for the help so far!
    The truck has lived it's entire life in Portland, OR. Little to no salt used on the roads but plenty of rain/moisture. I'll talk to my uncle and see if he's gotten a letter from Toyota about the frame rust issue.
    The suspension is stock.
  6. Jun 24, 2010 at 5:05 PM
    Barnone
    Barnone Guest
    DG,
    If the frame is badly rusted and Toyota fails it then bingo for your uncle at 1.5 times KBB retail.
  7. Jun 24, 2010 at 9:35 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Generally, Tacoma's that have spent their whole time in the Pacific NW do not experience frame rust issues. Exposure to moisture and mud are not the root cause of the rust problem. It is road salts which we don't have.
    btw: Welcome to TW.
