98 Tacoma Seat Belt Recall???
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1frkdog, Dec 30, 2012.
  1. Dec 30, 2012 at 8:38 PM
    1frkdog
    1frkdog [OP] Member
    1frkdog
    El Dorado Hills Ca
    98 Tacoma SR5 3.4 w/5spd
    KYB Shocks
    My 98 Tacoma x/cab has a faulty drivers seat belt issue. The metal bracket/frame the belt is pulled through right after the roller is causing the belt to fray along the length of one edge. It gets so bad the excessive frayed material gets hung up in the roller not allowing the belt to come out any further. Has anyone ever had this problem and/or has anyone ever heard of a recall for Toyota seat belts???
    Thanks,
    1frkdog
  2. Jan 1, 2013 at 12:58 AM
    vancitytaco
    vancitytaco New Member
    Mine is also very frayed along the edge from the same problem.
  3. Jan 1, 2013 at 1:00 AM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    every first gen I have been in has had a problem with seat belts retracting or coming out.
  4. Jan 1, 2013 at 10:13 AM
    Mossy
    Mossy Mechanic for Honda
    billy
    san antonio, TX
    ProComp lift Borla exhaust Borla air filter Nfab bars
    Mine won't retract. Got to manually feed it back in when I take it off
  5. Jan 1, 2013 at 11:20 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    Mine is fraying a little on the driver's side.
    passenger side gets less use I suppose.
    I doubt there would ever be a recall on wear and tear issues.
    If it's real bad... it's just time for replacement.
  6. Jan 1, 2013 at 2:34 PM
    fouillard13
    fouillard13 Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    mine is really bad. I have to heat up the cigarette lighter and burn it so it stops pealing.
