'98 Tacoma - Timing Belt & Fuel Filter Maint?
Discussion in '1st Gen. Tacomas (1995-2004)' started by OysterCracker, Sep 22, 2008.
  1. Sep 22, 2008 at 11:06 AM
    OysterCracker
    OysterCracker [OP] New Member
    Coastal SC
    Hey - First time here, great forums!
    I've got a '98 Tacoma 2.4L with about 90K miles. No big issues, and I'm trying to keep it that way. Looking at the manual, I can't find any reference to fuel filter replacement, and timing belt replacement is recommended at 90K, except for "T100/Tacoma/4Runner with 4 cyl"
    Are both of these items considered "lifetime" service on my truck?
    Thanks for your help,
    ~OC~ :)
  2. Sep 22, 2008 at 4:58 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    2.4L?
    I know the 2.7L's have a timing chain and doesn't need changed.
    Just not sure about the 2.4L....
  3. Sep 22, 2008 at 5:49 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Toyota says the fuel filter is a non-maintenance item, but with that being said, many have changed it out. But I hear it's a PITA to change because for the 4 banger you need to partially remove the exhaust manifold to get the filter out.
    The 2.4L also has a chain and doesn't need to be changed out.
  4. Sep 22, 2008 at 5:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to Tacoma World! Im pretty sure the 2.4 has a timming chain. Fuel filter is under the intake manifold. :)
  5. Sep 22, 2008 at 6:02 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Intake or exhaust? :confused:
  6. Sep 22, 2008 at 6:42 PM
    OysterCracker
    Coastal SC
    Thanks for all the quick feedback. That's good news on the timing chain. What's the opinion on the fuel filter? About 90K of normal use, no off-roading, no towing, probably a 30/70 mix of road/in-town miles, no noticeable signs of fuel problems or mileage loss. Do I keep on truckin' unless a problem shows up, or is the smart move to replace the fuel filter, regardless of what Toyota recommends?? Thanks,
    ~OC~
  7. Sep 22, 2008 at 6:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i would go ahead and change the fuel filter, even tho it may be a pita.....you could potentially get better mileage with a new filter if it has never been changed. its just me, but i change fuel filters every 15k............peace of mind, and they arent really expensive either.
  8. Sep 22, 2008 at 6:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you have the time, Give it a shot. I ran mine for 100,000 miles and didnt change it.
    Thats because on the V6 you can get to the filter even when drunk. :D
  9. Sep 22, 2008 at 6:59 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    this is very true man!!
  10. Sep 23, 2008 at 8:14 AM
    Ricky B
    Ricky B Well-Known Member
    Arkansas
    1998 XCAB
    I would change it. I changed mine after 95,000 and it had a lot of trash in it. Was really glad I did after I saw that. Rick
  11. Sep 29, 2008 at 6:30 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    1999 Tacoma 4x4, I did my timing belt at 60,000 because I bought it out of warranty and I wanted peace of mind, I also dit the h2o pump, which was showing signs of leaking, the 2 cam seals, and the fuel filter, which at 60K had all kinds of trash in it. Do it if it's on the cheap and it's good peace of mind.
