98 tacoma wont run
Discussion in 'Technical Chat' started by cq3853, Jun 16, 2011.
  1. Jun 16, 2011 at 6:58 PM
    cq3853
    cq3853 [OP] New Member
    1996 toyota tacoma 5spd well over 200,000. stopped at stop sign truck began to run rough like clutch wasnt engaged, then it died. cranks but will not start. tried small amount of ether ran for a second obd scanner used no codes. loosened banjo bolt and it was squirting fuel. several suggestions have pointed toward crank postion sensor. help!!!!!!!!!!!!!!!!!!!!
  2. Jun 16, 2011 at 7:15 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Don't use any more ether. Get the compression checked. That's about the only thing that won't throw a code. What motor are we talking about here? 3.4l or 2.7l
    Pull the plugs and look for coolant in the cylinder. Check the oil for water and the water for oil.
  3. Jun 17, 2011 at 8:42 PM
    JBSTRD
    JBSTRD Chicks Dig Body Damage
    Washougal, WA
    98 TRD Limited
    Donahoe CO's, OME Dakars w/Extra Leaf, 33" BFG KM2's, Warn 9.5XP, ARB Bullbar, AllPro Rear Bumper, Budbuilt Skid/Belly, Safari Snorkel
    Have you tried cleaning the IAC Valve?
  4. Jul 23, 2012 at 10:00 PM
    MSD2ndGen
    MSD2ndGen New Member
    So Cal
    96 Extened Cab 3.4L 5-speed
    I have the same problem with my 96 and I would check out the throttle body and clean it out cuz it gets guncted up and theres a thermal switch that gets nasty or the maf sensor they get dirty too and might help
