98 Tacoma won't start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tom9512, Aug 3, 2015.
  1. Aug 3, 2015 at 7:11 PM
    Tom9512
    Tom9512 [OP] Member
    Hi all,
    I need some help. I have a 98 Tacoma, 4 cyl 2.7 4x4. The truck has always started up fine with no problems, until this past weekend. When I turn the key, the relay box clicks rapidly, but it will not start.
    I checked online and figured it was the contacts in the starter and replaced those, but that didn't help.
    I got a junk yard starter today and still nothing.
    The battery is testing at 12.6V and I don't see any damage to any of the wires. All fuses are fine and the starter relay is in good shape as well.
    Do you have any thoughts on what else to try? I'm stumped.
    Thanks!
  2. Apr 27, 2016 at 9:11 AM
    jon4x4tacoma
    jon4x4tacoma Member
    did you ever figure this out because I have the same problem almost
  3. Apr 28, 2016 at 6:11 AM
    GA-3RZFE
    GA-3RZFE Well-Known Member
    2000 Taco 2.7L 3RZFE SR5 manual
    Complete rebuild at 197k miles
    Have the battery tested. It may show voltage on a multi meter of 12+ volts, but have almost no CCA. That can cause similar problems with the relay clicking.
  4. Apr 28, 2016 at 3:08 PM
    jon4x4tacoma
    jon4x4tacoma Member
    ok I will do that it seems we have had the same problem thank you for you advice
  5. Apr 29, 2016 at 7:54 AM
    Xyphon112
    Xyphon112 Well-Known Member
    I had a no start with my '98 where it sat for about a week then wouldn't crank. It had no relay click, but just a soft click then no noise. I hit the starter with a hammer softly about 5 times and it fire right up.
  6. Apr 29, 2016 at 2:35 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Cables could be corroded up inside the sheathing where you cant see??
  7. Apr 29, 2016 at 10:15 PM
    2ndtaco4me
    2ndtaco4me Well-Known Member
    MA
    13 Tacoma ltd & 02 Tacoma
    '02 Of course by no means am I a mechanic but my truck sat for a very long while (I did all the changing of the battery, gas additives) but in the end, I needed a new alternator & belt. Purrs like a kitten now. Mine did the clicking as well.
    One of the reasons it sat for a while also is that a critter chewed through the vacuum hose right on top of the engine and left a heck of a mess, his/her acorns. I replaced that hose too.
