98 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by TTacoma97, Apr 3, 2015.
  1. Apr 3, 2015 at 7:50 AM
    TTacoma97
    TTacoma97 [OP] Member
    I have a 98 Tacoma, and I been trying to figure out why my truck stalls when at a complete stop. When accelerating it is fine, but coming to a stop light it would stutter and shutoff unless I kept my foot on the gas.
    -tps already checked no problems
    -cleaned the carb
    Anyone have any ideas or exp this type of issue. I been trying to figure this out for past 7 months lol.. please helpp!!! thanks!
  2. Apr 3, 2015 at 7:56 AM
    doyouevenprerun
    doyouevenprerun Well-Known Member
    Jake from state farm
    Gilbert, AZ
    02 TuRD
    just got a simple lift on her
    That is weird.
    When you say cleaned the carb, what do you mean? Because there is no carbs on our trucks.... LOL.
    I would clean the mas airflow sensor, but other than that, i have no idea.
    Subbed for the information.
  3. Apr 3, 2015 at 8:34 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Not much info here :(
    4 or 6 cyl?
    auto or standard?
    stock or modified?
    recent work?
    What have you tried in the last 7 months?
    symptoms come on suddenly or gradually?
    What happens when, coasting with foot off the gas pedal? Still stall?
  4. Apr 3, 2015 at 9:03 AM
    TTacoma97
    haha i meant throttle body lol..
  5. Apr 3, 2015 at 9:14 AM
    TTacoma97
    6 cylinder
    standard
    all stock
    cleaned throttle, cleaned maf, checked tps sensor, happens every time when coming to a stop and giving it no gas. If im at a complete stop i can feel the truck trying to shut off than all of a sudden shuts off. if the truck is accelerating it has no problems only at a stop..thats all i have done in the past 7 months couldnt figure out what was wrong..could it be hoses? or anything? cel says something about tps sensor but that has been replaced and still has the same code
  6. Apr 3, 2015 at 9:16 AM
    doyouevenprerun
    Gilbert, AZ
    02 TuRD
    there is a sensor that makes the truck idle higher if it is going to die, i forget what the sensor is, but that is probably bad!
    normally if the truck is about to die because of low idle, the sensor would kick the idle higher real quick so it doesnt die.
  7. Apr 3, 2015 at 9:43 AM
    TTacoma97
    When at a stop it idles down quick then jumps back up than back down and shuts off.........siighsssss
  8. Apr 3, 2015 at 10:05 AM
    doyouevenprerun
    Gilbert, AZ
    02 TuRD
    get a test light and test the wiring, make sure its working properly!
    do you have a crack in your headers?
  9. Apr 3, 2015 at 12:19 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    The 5vze commonly has issue with a dirty idle control unit (IAC)
    And it's seems inline with your issue description.
    Intake cleaning may not clean the IAC fully.
    The internal vane inside the IAC gets dirty with carbon build up
    and sometimes can be stubborn to remove.
    I had to use a thin wood dowel to scrape the carbon
    build up off the vane...
    a good soaking first... helps break the carbon down
    making it easier to scrape off.
    Don't scratch the vane or interior when cleaning...
    if marred... it may never work properly again.
    that is why a thin wood dowel was used while cleaning.
    Tho' a good soaking first... will be necessary to soften that up.
    Make sure no chemical residue is remaining inside the IAC's interior
    after cleaning... or it could cause issue with other sensors.
    There are sensor safe cleaners available...
    but they may not soften the carbon enough to be scraped off.
    my '00 had similar issue around 120K.
    And after a few days or so of misbehavior (odd idling)...
    the engine wouldn't stay running at all (even with throttle applied)
    The IAC can be removed and if cleaned properly will likely work fine.
    It does require some effort to get to and remove.
    But isn't by any means difficult.
    Removal and value testing is covered in the FSM
    or DIY write ups can be found if searched.
    A replacement IAC is somewhat pricey
    if cleaning that does not correct the issue.
  10. Apr 3, 2015 at 12:40 PM
    TTacoma97
    So most likely you think this is the main cause of issue and nothing else?
  11. Apr 3, 2015 at 12:41 PM
    TTacoma97
    you mean the wiring for the maf? my tps is brand new...
  12. Apr 3, 2015 at 12:44 PM
    doyouevenprerun
    Gilbert, AZ
    02 TuRD
    No, i am talking about for the IAC that tacodell is talking about.
    im willing to bet its what he said.
  13. Apr 3, 2015 at 1:03 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    There can always be additional faults...
    But your reference to the erratic idle (up/down/stall) at start...
    is exactly what mine was doing when it failed.
    Cleaning the IAC... fixed it for me.
    I have done this on several 5vze's with success.
    Including for a friend that purchased a junk yard 5vze
    to replace his 5vze that threw a rod.
    In his case... I was able to clean it up with my dowel
    and some brake cleaner.
    Was purdy sweet to hear his junk yard motor fire up and purr at idle.
    His junk yard 5vze was dang dirty internally...
    and we had to do three oil changes to get that dirty out.
    We also had to clean the intake as that had been seriously neglected.
  14. Apr 3, 2015 at 1:31 PM
    TTacoma97
    thanks!!
  15. Apr 3, 2015 at 1:32 PM
    TTacoma97
    Thanks, I will try that out!
  16. Apr 3, 2015 at 11:02 PM
    zilch
    zilch Member
    zilch
    Vacuum line?
  17. Apr 6, 2015 at 9:14 AM
    doyouevenprerun
    Gilbert, AZ
    02 TuRD
    i had vaccume line problems all the time with my truck a while back, but it would never actually die because the iac would kick the idle back up.
