'98 to '04 3RZ swap ?
Discussion in '4 Cylinder' started by Dustrider, Jan 21, 2014.
  1. Jan 21, 2014 at 9:23 PM
    Dustrider
    Dustrider [OP] Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    Hoping to find a used motor for my 1998 4x4
    Can I swap a 1998 3RZ to a 2004 3RZ ?
    also :what about using a distributor 3RZ ? can the distributor be removed and plugged and install the cam sensor from the 98 ?
  2. Jan 26, 2014 at 4:31 PM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    You probably wouldn't have an issue with an 04 as long as you used the ignition system from the 98. I would just double check the sensor setup. Just make sure you can adapt it to your harness.
  3. Jan 26, 2014 at 5:20 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I believe the 98 uses a 2 coil system, not a distributor.
    The 04 uses a coil on plug system.
    The install shouldn't really be an issue. You may have to use the lower intake plenum from the new engine with your upper plenum from your current engine.
    Other than that, most of stuff should be the same. Might have to swap some sensors over due to changes in wiring over the years.
    See the picture for differences in intakes.
