'98 to '04 3RZ swap ?
Discussion in 'Technical Chat' started by Dustrider, Jan 23, 2014.
  1. Jan 23, 2014 at 10:27 PM
    Dustrider
    Dustrider [OP] Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    If I have 2 fully complete motors with all engine controls and mine is a 1998 3rz, the replacement might be a 2004 4runner 2.7 (assuming its a 3rz)
    Does anyone know if I will be able to just swap out the valve covers and use the coil packs instead of the COP's ?
    I assume the pointer for the pickup coil will be on all 3rz cams
    if its a 4 port head, can I put my '98 throttle body and other engine control junk from my 8 port plenum onto a 4 port plenum ?
    I assume my 5 spd bell housing will bolt up after removing the 2004 auto housing
  2. Jan 23, 2014 at 10:29 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    You have to use the 2004 engine parts on the engine.
  3. Jan 24, 2014 at 12:10 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Changing from the 8 port to a 4 port will affect engine performance. You don't want to mix that. While the base engine is 2.7L, there are several mechanical and electronic changes that can cause problems with doing a swap over that many years.
