98 to 04 grille swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by calebdnehus, Jan 11, 2015.
  1. Jan 11, 2015 at 6:56 PM
    calebdnehus
    calebdnehus [OP] Well-Known Member
    Caleb
    Arkansas
    '98 Prerunner V6--2004 Tacoma facelift
    K&N cold air intake FPIK, FlowMaster 40 series muffler, Euro Diamond clear headlights, 2003 tacoma tailights, bixenon HID headlights, 4 inch lift, pioneer headunit w/kicker door speakers(amped w/Rockford four channel), 2004 facelift, led dash light mod, painted needles, black auto shifter, leather steering wheel, ultra gauge. Plenty to come... Still
    Having trouble getting my corner lights to sit flush to the fenders
  2. Jan 11, 2015 at 7:56 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    you have to switch fenders or do serious body modifications to it to make it look right
  3. Jan 11, 2015 at 8:00 PM
    calebdnehus
    Caleb
    Arkansas
    Well I've seen a couple other swaps like this and made it work somehow without new fenders. Its probable I'll need the 01-04 fenders I guess. But I've messing with it as I've had time and it just seems like something is holding it up, from what I can tell it seems like the grille isn't setting back far enough. The passenger side corner light sets a lot closer to the fender as opposed to the driver side
  4. Jan 12, 2015 at 7:06 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    The fenders are the same to my knowledge but the mounts might be different.
    PM'd.
  5. Jan 12, 2015 at 8:01 AM
    calebdnehus
    Caleb
    Arkansas
    The mounting style is a little different. PM heading back your way
  6. Jan 12, 2015 at 8:03 AM
    Madjik_Man
    Colorado Front Range
    STLHarry is your man.
  7. Jan 12, 2015 at 8:18 AM
    calebdnehus
    Caleb
    Arkansas
    Yeah, I saw his thread on the swap he did and it looked prefect. Way better than what I came out with, haha
  8. Jan 12, 2015 at 10:13 AM
    Madjik_Man
    I did a 98 to 97 grille swap (you went the wrong way with the swap :p ) so if I can be of any help let me know.
    I took a lot of pics which can be found in my build thread.
    Also - you might want to change the thread title to "98 to 04 grille swap." Don't know if it'll make a difference with soliciting help... but it's killing my OCD :eek:
  9. Jan 12, 2015 at 10:25 AM
    calebdnehus
    Caleb
    Arkansas
    Yeah, I'll definitely be checking out your build for the pictures. How do you change the title? I was trying to do that last night but I never found it
  10. Jan 12, 2015 at 10:31 AM
    Madjik_Man
    I think you click "edit" then "go advance"
  11. Jan 12, 2015 at 10:48 AM
    keakar
    karl
    louisiana
    ok, I got bad info then. when I was asking about it I was told the fenders had to be switched.
    glad to know that isn't the case, I guess free advice isn't always good or accurate advice.
    I may do this swap myself, it sure looks nice
  12. Jan 12, 2015 at 10:57 AM
    calebdnehus
    Caleb
    Arkansas
    You definitely should man, I love it for the most part. Those lights are just killing me though, my ocd kicks every time I see it. I'm almost certain that the grille just needs to be adjusted to make the sit down because it looks like the bottom of the light is being pushed out by something
  13. Jan 12, 2015 at 10:59 AM
    calebdnehus
    Caleb
    Arkansas
    Thank you sir! It has been addresed. Haha
  14. Jan 12, 2015 at 11:05 AM
    keakar
    karl
    louisiana
    maybe you need to swap out the brackets that the lights sit before mounting to the truck or drill new holes, I bet its going to be something simple like that
  15. Jan 12, 2015 at 12:09 PM
    calebdnehus
    Caleb
    Arkansas
    I have been thinking about getting a core support from the 01-04 year trucks. I dont know if I can just buy the mounting bracket for the headlights. Mine was connected to my core support
  16. Jan 12, 2015 at 3:39 PM
    keakar
    karl
    louisiana
    I ewas thinking you could swap them with he original lights
    as to the core support im not sure what other things might change like radiator, a/c, horn, and all that so keep in mind (stuff like that may not line right up the same or maybe it will) just be careful you don't create more alignment issues trying to get the lights done
  17. Jan 12, 2015 at 4:13 PM
    calebdnehus
    Caleb
    Arkansas
    When you say swap them with the original lights, do you man using a set of 01-04 mounting brackets?
  18. Jan 12, 2015 at 4:54 PM
    Madjik_Man
    I assume you had the same problem as I did... the holes in your 98 core support are nowhere near the same shape as the headlight mounting brackets.
    We had to cut and peel the sheet metal of the core support to accept the brackets of the 97 headlights.
    And the thing with our 98 is that the mounting brackets aren't simple metal buckets, they are those gargantuan plastic brackets.
  19. Jan 12, 2015 at 7:48 PM
    calebdnehus
    Caleb
    Arkansas
    The 01-04 headlights fit in the hole in 98 support but they did have a big black plastic piece toward the inside of the grille. I had to cut my 98 headlight mount brackets out and fab my own for the 01-04 headlights. I used self tapping screws to hold my brackets in. I may have screed them down to far out but my grille still fit really well.
  20. Jan 12, 2015 at 7:57 PM
    Madjik_Man
    And you're still able to adjust your headlights?
