98 Toyota Tacoma Prerunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by panamaborn, Feb 28, 2017.
  1. Feb 28, 2017 at 3:45 PM
    panamaborn
    panamaborn [OP] Member
    1998 Toyota Tacoma
    none
    I want to fix up my truck, replace the exhaust system put in a header if it is available, change the suspension replace the existing front and rear shocks to a better suspension. My truck is a two wheel drive automatic transmission with a 2.7L engine. Replace the spark plugs and wires to a better one update from the existing factory ones. Any suggestions? Not looking to buy a new truck just fix up the old truck make it run and drive a little smoother. Thanks for any suggestions.
  2. Feb 28, 2017 at 3:51 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Bilstein or Old Man Emu shocks. Is your exhaust manifold cast-iron or tubular? Toyota factory parts are best to use. Have you checked your lower ball joints recently?
    panamaborn[OP] likes this.
  3. Feb 28, 2017 at 4:01 PM
    panamaborn
    1998 Toyota Tacoma
    none
    Thanks for the reply it's funny you mentioned the ball joint I was driving home and the right front wheel came off. I replaced both upper and lower ball joints on both sides. Not really sure about the exhaust manifold? Where can I find out more information on the shocks you mentioned? Toyota parts are very expensive.
  4. Feb 28, 2017 at 5:10 PM
    mechanicjon
    Jon
    Scottsdale Arizona
