98 windshield fluid reservoir bolt size?? help??
Discussion in '1st Gen. Tacomas (1995-2004)' started by kwhorne, Oct 7, 2014.
  1. Oct 7, 2014 at 11:40 AM
    kwhorne
    kwhorne [OP] Active Member
    Kevin
    Augusta, GA
    1998 Tacoma SR5 Xtra Cab 4x4
    I am doing the fiberglass repair on the neck of my reservoir and I removed it several months ago and just now getting around to the repair.. I can't seem to find the 4 bolts that hold it onto the truck... I believe they are 10mm but does anyone know the length??? Thanks in advance!
  2. Oct 7, 2014 at 3:31 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    10mm = 3/8" so look at the flanges and figure out how long they need to be
    I cant see where them being too long is an issue so get them a little long if you aren't sure but my guess is 3/4" (20mm) to 1 1/8" (30mm) long is what they will be
  3. Oct 7, 2014 at 6:19 PM
    kwhorne
    Kevin
    Augusta, GA
    thanks, I actually found them
