98 with P0500 code
Discussion in '1st Gen. Tacomas (1995-2004)' started by theletohouse1276, Aug 20, 2023.
  1. Aug 20, 2023 at 9:35 PM
    theletohouse1276
    theletohouse1276 [OP] New Member
    98 Red Tacoma SR5 column auto 2.4l
    I’m new here but have been looking a lot. But I do need help
    I have a 98 Tacoma SR5 2.4L automatic (on the column) so here goes my issue
    CEL with P0500 code
    Speedometer and odometer work perfectly. Cruise comes on but won’t set. Had the cluster checked, came back ok. Replaced ECU as recommended by local dealer. Had to find a reman. But 30 miles later, cel. Anyone have a clue?
  2. Aug 20, 2023 at 11:47 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Welcome to the forum!!
    Has this ever worked correct?
    Anything stand out right before the code tripped the first time
    Never forget the wiring that connects every thing!!
    Sure sounds like a intermittent open circuit.
    Might be a loose pin or a broken wire. Doing electrical trouble shooting without The Toyota wiring diagrams is very frustrating.
    Good Luck!!
