99 2.7L how to clean throttle
Discussion in '1st Gen. Tacomas (1995-2004)' started by tomary98, Oct 1, 2010.
  1. Oct 1, 2010 at 1:54 PM
    tomary98
    tomary98 [OP] New Member
    OK, so I'm a dumb chick :rolleyes:, but how do you take off the air intake to clean the throttle body? We are having trouble getting everything loose. Please explain step-by-step! Thanks so much for your help!
  2. Oct 1, 2010 at 4:03 PM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    Your 99 should have the same system as my 01, there are a set of 4 metal clips at the 4 corners. You just push up on the clips and unsnap them, then the top of the airbox lifts off. Welcome to Tacoma world, and since you're a female you're sure to get LOTS of responses. If I asked this question I'd get "use the search" or maybe just a shrug:)
  3. Oct 1, 2010 at 7:09 PM
    tomary98
    No, I want to get the throttle body cleaned. we loosen the screws that hold on the hose right there, but then what? we can't get the hose pulled off. is there something else there we're supposed to be loosening?
    Thanks!
  4. Oct 1, 2010 at 7:11 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    seafoam?.....amsoil throttle body cleaner
  5. Oct 1, 2010 at 7:15 PM
    crf69
    Ohio
    ummm yeah
  6. Oct 1, 2010 at 7:25 PM
    kingston73
    eastern MA
    09 SR5 4.0L 4x4
    Oh, got it, sorry I misunderstood. So you're trying to take the air intake tube off to get to the throttle plate, right? It's still easiest to take off the airbox first. I do it but I'm sure others might tell you other ways:
    1. unplug the MAF sensor and take the top off the air box.
    2. disconnect the air intake from the airbox
    3. loosen the clamp at the throttle body and rotate/pull the intake tube, it'll come off you just need to loosen the clamp a lot first.
    You can probably do it by just loosening the one clamp but I think it's just easier to take it all off.
