99 3.4L Hard start then dies immediately.
Discussion in '1st Gen. Tacomas (1995-2004)' started by captn.taco, Jun 15, 2019.
  1. Jun 15, 2019 at 5:03 PM
    captn.taco
    captn.taco [OP] New Member
    1999 Toyota Tacoma 3.4L
    Hello, I have a ‘99 3.4L V6 that I just picked up. Owner said it died while driving. So far I have replaced the fuel pump, and fuel filter. I can feel the efi relay kicking on, as well as the open circuit relay. Every couple tries it will hard start but it will start for 2 seconds and then die. Battery is good too. Any ideas?
  2. Jun 15, 2019 at 6:06 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    What are the MIL codes currently on it?
    Wyoming09 and Taco critter like this.
  3. Jun 16, 2019 at 5:54 AM
    villlein
    villlein Well-Known Member
    Ham
    04 Tacoma
    SAS with dodge D60/D70, 36 iroks, 5.86's welded rear, Eaton lock, OBA, half back cage, rear mount radiator, etc...
    Spark, Fuel, Air, and Compression are the big 4. I worry about compression after all the listed below \/
    I'm assuming you have good crank (ie checked (+) connections at stater, alternator and battery for corrosion and tightness). I would then check for actual fuel at the rail. Check throttle blades for good movement. Check oil level. Check for coolant. Run through the spark wires for good connections, add a little seafoam and start.
    I find if things sit for a while, they can really suck battery power even with a new battery. So at the same time, Ill jump start them so I know I have enough crank power to blow out any gummy material and get things turning.
    Also not a bad idea to run through the fuses to double check.
    *Sometimes I found that an accessory is seized, and you can hear belt squeal, or see belt debris. Steering pump, Alternator, generally. The A/C can cause problems at the crank, but generally they burn out but don't seize. Sometimes they can cause a start then stall scenario.
    TacomaJunkie8691 likes this.
  4. Jun 16, 2019 at 6:43 AM
    02hilux
    Planet: EARTH
    Do a compression test.
    For those 2 second when it run, how does the engine sound? Smooth or stuttering?
    Might be a bad sensor if it's able to start. Maybe MAF?
  5. Jun 16, 2019 at 5:03 PM
    captn.taco
    With key on it has its check engine but with a scanner on it I can’t get it to run long enough to give me any info. All the fuses are good.
    Pulled a plug and definitely have spark. Also pulled the supply hose on the fuel rail and have plenty of fuel, now at least. It was building up pressure in the gas tank but that stopped after replacing the fuel filter.
    When it runs it doesn’t sound exactly right, so my brother is thinking it could be something timing related. This weekend we are gonna check on that. Ran out of time to finish on Saturday but will definitely keep updated as soon as we get to work on it again this weekend. (Also, will clean up the MAF, and do a compression test.)
    Thank you so much for the help!
  6. Jun 17, 2019 at 12:57 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It will pull codes without the engine running .
    Then if the battery was disconnected the codes are cleared
  7. Jun 17, 2019 at 4:14 AM
    zach141b
    zach141b Well-Known Member
    Zach
    Louisiana
    2001, double cab, 4WD, 3.4L Tacoma
    I have a friend who picked a non- or barely running 3.4L Taco recently. Its timing belt was missing teeth; it was grossly out of time. Perhaps that's your problem.
