99 bucks for rear dif gear oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spencer97TJ, Feb 24, 2016.
  1. Feb 24, 2016 at 8:56 AM
    Spencer97TJ
    Spencer97TJ [OP] Well-Known Member
    Spence
    CT
    stock
  2. Feb 24, 2016 at 9:48 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    Synthetics are awesome in areas that do not get change frequently- like x-case, diffs, and trannys. Have that peace of mind. Also they can reduce friction loss through a drive line. I have picked up measurable difference by swapping out fluids on some of my vehicles. So the $100 feels a bit stiff-especially to a do it self-er like me but hopefully knowing you got a little bit better product helps?
    Spencer97TJ[OP] likes this.
  3. Feb 24, 2016 at 9:57 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    that's about right. it seems steep, but if you break it down......
    Oil- $45
    new plug washer/seal- $5
    probably charged you a "shop fees" charge, to cover stuff like towels, degreaser, etc - $10
    labor for the hour (round up) that it took at $40/hour minimum.
    Total before tax $100
  4. Feb 24, 2016 at 10:51 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I got 12 qts of Mobil syn for $98 - did diff, T case and trans and had plenty left. If U R at all handy there's not much to it and a lot of $$$ in you pocket instead of theirs.
  5. Feb 26, 2016 at 6:32 AM
    Spencer97TJ
    Spence
    CT
    stock
    I can figure it out for sure. it's just the dumping of it and the free time thing.
  6. Feb 26, 2016 at 6:42 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The link you provided shows 75W140 grade oil? That's a very advanced grade of oil, and allows your diff to run hotter without the oil breaking down, useful if you like to do burnouts :D or see a lot of wheelspin off road (mudding, etc.).
  7. Feb 26, 2016 at 6:48 AM
    Kyle01
    Kyle01 Well-Known Member
    Kyle
    Chicago
    2024 TRD Offroad double cab 6MT
    I asked my mobil1 oil change place what they would charge to do the diffs/t-case (it's winter and shitty here) They quoted $100per ($300 for all 3)
    I went and got mobil1 synthetic ($60 for 6 quarts) and did it. That was a little too rich for my blood.
  8. Feb 26, 2016 at 8:06 AM
    george3
    New Jersey
    I dump it at work but that won't help you. I used to dump it a the town dump pronounced Recycling Center. Some Mechanic/gas stations use to take it. Some places with a lot of equipment use recycled oil to heat their garages - that's another spot to dump - you just have to ask around. Can't help you with the time - I do it on a weekend when the sun is shinning and the temp is reasonable. At one time I had Jilly Lube doing my oil changes because it was cheap but then I found out it wasn't good - they told me I didn't have zerks or when I pointed them out they yes'd me but when I did them myself water came out so the proof is in the pudding - they didn't do them.
  9. Feb 26, 2016 at 8:33 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    most autoparts stores have free oil disposal. just give your local one a call.
