99 Mystic 3RZ and Adventures Build
Discussion in '1st Gen. Builds (1995-2004)' started by brettf, Oct 26, 2018.
  1. Nov 1, 2018 at 8:18 PM
    brettf
    brettf [OP] Well-Known Member
    Pretty limited on time at the minute, so I'll be just chipping away...
    First order of business is the rear bumper. I put that out to inspect. Looks stout!
    Another angle:
    Grabbed the old bumper bolts for test/fit, mockup and dragged it all out to the truck:
    That's as far as I got before the trick-or-treaters started rolling in. Other bonfire and
    beer related duties had to be fulfilled as well!
    Didn't get back to it until the next night, which ended up being all in the dark.
    Enlisted some help for lifting it roughly into place. It fit tight to the frame. Used
    a dead-blow and a 2x4 to gently motivate it until mounting holes lined up.
    I think it looks good, but I can't really tell by headlamp. I'll take a look and post
    some pictures in the daylight!
    Chipping away...
  2. Nov 1, 2018 at 8:22 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Nice truck! I like the color.
    I can’t imagine the 3rz with 3.58 gears. :eek: You’ll be amazed when you get around to re-gearing.
  3. Nov 1, 2018 at 8:30 PM
    brettf
    It's as fast as a glacier! Yeah I'm looking forward to that phase for sure.
    rngr likes this.
  4. Nov 2, 2018 at 11:26 AM
    brettf
    Some shots of the bumper in the daylight. Looking good. Need to align slightly better yet:
    Not much room for a step:
    Out with the old, in with the new:
  5. Nov 7, 2018 at 7:39 PM
    brettf
    Thinking about tires.
    Not sure where I'll go with this in terms of tires between MT and AT. Thinking BFG KO2 or KM3.
    I've had very good experiences with BFG and I'm a big fan of known quantities...
    I'm all but certain I'll go with a 33" tire, I'm not sure what sizes, widths are available in those so
    I have some homework to do. I've liked pizza cutter tires in the past, especially for these light(ish)
    trucks, but I'm not leaning that way at the moment.
    In any case, here's a shot of the tire that's currently on it:
    I dragged out a 256 70 17 that I pulled off another truck when I replaced these tires. Still 6/32s"
    left, so will possibly run these as spares for other vehicles or on the Mystic if I go crazy and decide
    to run a 17" wheel on this truck.
    These "fit" well in terms of how they are proportioned based on this very non scientific test. But
    I'm pretty sure I'll do 33" and run the stock wheels if I can find the right tire size/width for old school
    15" wheels. I really liked these the OE wheels, just good honest, simple styling... but everyone has their
    own taste.
    Anyway, here's the 265 for grins:
  6. Nov 7, 2018 at 7:45 PM
    brettf
    Finally getting the truck inside so I can get into it more (and lay down in the mud less!)...
    boostedka likes this.
  7. Nov 7, 2018 at 7:56 PM
    brettf
    Finally getting more into it! Getting a few things done by getting the truck up on stands and pulling the
    coilovers out.
    Looks ok - light surface rust on some things, shocks turned to crap 50K miles ago, fasteners look
    manageable...
    Little extra breaking force needed. Thanks old pile of parts...
    Not too bad with assembly out. I've seen this area get gnarly on some trucks from rusty states,
    this is a Colorado vehicle, very happy with what I continue to find... Antijinx!
    Coilover out...
    Not bad for a quarter million miles!
    Need to get the middle washer and middle bushing from Toyota unless they are cost prohibitive parts.
    I'll be making a stop at the local parts dept to check on it tomorrow...
    Quick comparison between the shock bodies:
    Aaaand out of time! Chipping away!
    rngr and boostedka like this.
  8. Nov 9, 2018 at 9:25 PM
    brettf
    Couple more quick updates.
    Had a couple of things to figure out before I could assemble the 6112 coil-
    overs: One was the OE top hat, which had to be removed from the old coils
    and re-used on the new assembly. The second was a bushing and washer
    that Bilstein calls for being OE. These fit immediately below the top-hat.
    Ran over to Toytec for the bushings (great that they are local!) then I mocked
    everything up in order on the shock body. Not having a spring compressors
    is a great excuse for not compressing springs myself! So I swung by a local
    shop that I highly recommend to have them compress the old coils, take apart
    the assemblies, put the top hats on the new 6112s, compress and tighten...
    Japanese Auto Service in Wheatridge CO has always been great for me. They
    have a new rig that makes compressing springs easier and safer.
    Removed the stock UCAs without any drama. I forgot how long those UCA
    bolts are! Had to remove a handful of bolts in the engine bay to allow the
    long bolt to slide forward for removal, but nothing crazy.
    Gear Ties are the best for holding things like spindles in place... UCA out:
    Went with the Total Chaos UCAs in the end anyway. Got a screaming deal on them
    and decided I couldn't pass it up...
    Of course since then I've had a bunch more feedback similar to you guys on here
    about more reasons to run SPC and other brands... noise being a chief complaint.
    I guess I'll see! Hopefully this won't turn into something I regret. Anyway, they
    sure look like nice units. Packaging and instructions are excellent.
    Pressed in the bushings and sleeves this afternoon, have work to do on the driver
    side to catch up. Then work on the upper balljoint removal and UCA installation.
    No more time! Keep making a little forward motion!
  9. Nov 11, 2018 at 7:29 PM
    brettf
    Got a little more done. One more nice day with the doors open yesterday. Weather changed last night!
    Working all day today while the snow piled up.
    Here's my shop light. Helmet with night riding light rockin' Super bright. Can put it down, can
    wear it, great light actually!
    Had a little more evening time to press out the upper balljoint on passenger side. I greatly
    underestimated that job. I tried to do it the "right" way and press everything out perfectly.
    I was ultimately successful, but it was not worth it. As soon as I have more time to make a
    little progress, I will just cut-of-wheel the joint off the driver side ball and press that sucker
    out.
    Couple bad pictures of UCA in and spindle with no balljoint in it:
    boostedka and rngr like this.
  10. Nov 12, 2018 at 4:57 PM
    brettf
    OK, a little bit of knowledge goes a long way. The first upper ball joint took me hours to get out
    cleanly.
    The second was probably 30 to take out and press in the new TC UBJ replacement sleeve.
    Cut that bad boy off and brute force press it out. Don't try to take it out intact... don't know
    why I was hung up on doing that.
    Stack of press tools to press in the new TC part:
    New part in, driver side:
    New part in, passenger:
    That's it for now, out of time. Changing the world 30 minutes at a time!
  11. Nov 17, 2018 at 8:42 PM
    brettf
    Not much to report. Been very busy with work.
    Did get a little time to install the coilovers into the stock LCA and new UCAs. Little bit, okay a
    lot, of shifting and prying to get them in and good to go. I found that running the lower shock
    bolt the obvious way from the front of the vehicle towards the back is easier, but not ideal as it
    is more difficult to torque correctly (though it looks like it can be done). So I ran the bolt from
    the inside of the mount towards the front of the vehicle so the nut is exposed towards the front
    in order to make it easier to access so I could torque correctly.
    A little progress here and there on cleaning up some old wiring under the hood. Also found time
    to drink a beer in the garage! Life continues to be good. Progress, however, continues to be
    slow! :)
    rogerman and boostedka like this.
  12. Mar 29, 2019 at 1:40 AM
    Islandtruck
    Islandtruck Active Member
    Merlin
    1997 Tacoma 4x4 3.4L Automatic
    Bilstein 6112, Dakar leafs,
    Great looking truck! Have you had a chance to try out those 6112’s yet? I am thinking about getting some for my stock ‘97.
    mattvivsound likes this.
