99 prerunner 2.7L - radiator flush question!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zer0, May 19, 2014.
  1. May 19, 2014 at 5:57 PM
    Zer0
    Zer0 [OP] Well-Known Member
    SGV, California
    99 PreRunner
    Hello. I recently flushed out my radiator and ran some water through to try to clean it out. When I added new radiator fluid, I only used a gallon of fluid and the radiator was full. I then started the engine for a minute and then added a little more fluid and it got full. Is this normal to only use a gallon of radiator fluid to completely fill the radiator? I was told that it took 2 gallons. I also wanted to mention that when initially added fluid, the car key in the ignition was turned to the ON position but the engine was not turned on itself (must have left the key in ON position and on neutral because I had previously pushed the car to move it). Is this normal for the radiator on 2.7 to only use a gallon of fluid? Thanks
  2. May 20, 2014 at 12:36 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    I think you might have not drained the engine block via the drain valve just under the exhaust manifold near the front of the engine. It's a little hard to see at first. There is a small spout facing downwards with a bolt on it. I think it's a 12mm or might be a 10mm.
    Opening this will get more out.
    I use a flush machine at work. Do mine every year and it takes about 2 gallons. However, the machine will push as much as I place in it before it stops. I use 3 gallons just to be sure everything is out.
  3. May 20, 2014 at 11:32 PM
    geoff06
    geoff06 261k and counting
    WI
    '01 PreRunner Xcab lifted
    3" lift, Bilstein 5100/OME coilovers, rear AAL, Swiss camper shell, Rough Country 9000 rear shocks, 265/75/16 AT's on stock steel rims painted black, All-Pro 1.5"F/1.25"R wheel spacers, airbox elbow mod, Flowmaster Super 44, Davico post-cat, I took off my DIY angle iron bed/light bar!, bed wheel well shovel-mount, blacked out grill emblem, Poineer DEH-P3900 head unit, Alpine Type R front component speakers, Pioneer Coaxial rears, Dynamat in door panels, scratchbuilt aluminum holders for my ipod nano and phone, and for some reason, I painted the headlight fillers black...
    X2 on the engine block drain plug. 12mm does sound right... it was 3 years ago for me though. You can also squeeze the radiator-to-block (cold) hose to help remove some remaining coolant when you drain (might not be necessary for a flush though). Also don't forget to use a mixture of coolant/distilled water.
  4. May 23, 2014 at 7:12 PM
    Zer0
    SGV, California
    99 PreRunner
    Thanks for replies! When I drained out my radiator, all I did was remove the drain plug from the actual radiator....I didnt know there was another drain plug -this is probably why I only was able to add 1 gallon. I probably have another gallon of old coolant still in the engine. Damn it! Now I'm going to have to do this process again...well I guess this is how you learn right? lol
    Where is this other drain plug located? Does anyone have pics of what this drain plug looks like and where its located? Do you think I may have damaged anything flushing the coolant the way I did? I also ran a water hose through the radiator for a good 5 minutes. Do you think I may have gotten water in the block where the other coolant is? I'm going to need to redo the whole process tomorrow. Whats the easiest way to access this other drain plug and do I access it from the top of the engine or do I need to crawl under. Thanks! Also any tips would be helpful too. What a fail I did on this :(
    Forgot to mention that I used a 50/50. Is the 50/50 better then pure coolant with adding water? thanks again guys
