99' PreRunner Taco LSD, locker info
Discussion in '1st Gen. Tacomas (1995-2004)' started by KYREBEL, Sep 22, 2008.
  1. Sep 22, 2008 at 11:59 AM
    KYREBEL
    KYREBEL [OP] Member
    99' PreRunner 3in Daystar lift
    i have a 99' prerunner with the 2.7 automatic, and i have noticed only one tire will pull since i have had it, is there some kind of posi, limited slip, or something that is in there and could be messed up?
  2. Sep 22, 2008 at 12:02 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    on my 98 i only had one tire pulled. do u just have the standard pre runner??? im assuming u do since u got the 2.7 since the trd comes with those differential options. your fine
  3. Sep 22, 2008 at 4:28 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    All first gen Tacos without the TRD package have only 1 tire that actually spins to move the truck forward. With the TRD package you had the rear diff lock that made both rear wheels spin.
  4. Sep 23, 2008 at 12:13 PM
    KYREBEL
    KYREBEL [OP] Member
    thanks fellers just curious, goin wheelin this friday i will try to put some pics up in the offroad forum this weekend sometime
  5. Sep 27, 2008 at 7:17 AM
    prophet
    prophet Member
    Peoria
    PreRunner SR5
    Somewhere somebody posted that all Prerunners have at least an LSD. It's an option. I added a Detroit Truetrac LSD to my 04 last month. It took about 3.5 hours to install. I'll have to keep everyone posted when I can put it through the gauntlet...or at least a snow storm.
  6. Sep 27, 2008 at 3:25 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Nope, not true, at least for 1998-2000 PreRunners, not sure for 2001-2004. Now if you're referring to the rear diff lock then it was part of the TRD package.
  7. Sep 27, 2008 at 8:32 PM
    prophet
    prophet Member
    Peoria
    PreRunner SR5
    Are you saying LSD wasn't an option even, back in the 98-00 Prerunners? Didn't know that.
  8. Sep 27, 2008 at 8:36 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    That would be an affirmative.
  9. Oct 4, 2008 at 12:06 AM
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA
    2018 TRD PRO
    I'm looking into getting a truetrac for my 08 TSS. Is the truetrac all I have to buy and swap out, or are there additional parts to get?
  10. Oct 5, 2008 at 7:13 PM
    prophet
    prophet Member
    Peoria
    PreRunner SR5
    The LSD and some new bearings would probably be a good idea too. You may need a shim kit though to maintain the proper backlash. My 04 did not need any shims...the stock plate washers (these act as shims on the 04 8.4" differential) move the assembly one way or the other based on their thickness and how far you need to move the Differential/bearing assembly to obtain your backlash number. Keep us posted.
  11. Oct 5, 2008 at 9:00 PM
    CJH9980
    Clint
    Shreveport, LA
    2018 TRD PRO
    thanks for the info. I'm going to do a little more research first before deciding between the truetrac and a selectable locker. I was just about sold on the LSD until a buddy told me about problems he's had with the LSD on his silverado when one wheel is in a rut. I'll definitely keep my progress posted
  12. Oct 5, 2008 at 9:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The Detroit Tru Track is a good unit. If your looking for a ful time LS, you cant beat it. :)
  13. Oct 5, 2008 at 9:57 PM
    CJH9980
    Clint
    Shreveport, LA
    2018 TRD PRO
    just to clarify, is it true that you will still be stuck if one of the drive wheels is off the ground? My friend told me that his LS is just as useless as an open diff in that situation
  14. Oct 6, 2008 at 3:42 AM
    prophet
    prophet Member
    Peoria
    PreRunner SR5
    The manual says if the one wheel is off the ground you can tap the brakes and get the other wheel to engage.
  15. Oct 7, 2008 at 2:22 PM
    CJH9980
    Clint
    Shreveport, LA
    2018 TRD PRO
    Well, I ordered my TrueTrac today from a local offroad place, it should be here by Monday :)
